"FL" flashes if any overfill condition occurs. This condition occurs when
excessive water in the tub causes the overfill switch to trip. The control
must realize that the trip was due to an overfill condition instead of a
suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds
with no time out. The pump is cycled in drain mode for 30 seconds on, 30
seconds off until the overfill switch resets or power is discontinued to
the unit. Press STOP/CANCEL to clear the display.
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
“FL” (Over Fill) flashes The washer will beep every 10 seconds with no time-out. The pump will cycle one half minute on, one half minute off, until the overfill switch is reset or power is discontinued to the unit. Press STOP/CANCEL to clear the display. Shut off the water faucets to the inlet hoses if water continues to flow.
The FL error code means: Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&!$$
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
FL
Flood condition
the unit.
"FL" (Over Fill) flashes
The washer will beep every 10 seconds with no time-out, The
faucets to the inlet hoses if water continues to flow,
If it still happens you need to get a service guy out.
"FL' (Over Fill) flashes
the over fill switch is reset or power is discontinued to the
