Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I lost my manuel & don't know how much salt I am supposed to have in it. My pool is an Intex 16 X 48.
    Problem Solver:
  • 11 Answers
I checked the manual.
For an Easy Set you need 110 lbs of salt
For the Metal Frame you need 125 lbs of salt
If you go online to the IntexCorp website, you can download an additional manual for free, takes a while to do but that way you'll have all the info in case you have any more problems.
Good Luck!
Posted on Jun 15, 2009
Model CS8111 ... How much salt do i put in an Intex Easy Set Up Pool 15 x 48" for the 1st time?
The ideal salt level is between 2500-3000 ppm (parts per million) for this model - the optimal level is 3000ppm.
For a round pool with your dimensions of 15 feet across and 48" deep, with the water at 80% capacity (it's not filled to the top right?) = 3736 gallons. So the amount of salt you need to add initially to get to 3000ppm is 95 lbs of salt.
When low salt is detected (Code 91) you are supposed to add 20 lbs of salt (what the manual says).
Here is a link to the manual that I found : (see page 133)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiQxM-mmNHNAhVH52MKHRkCDe4QFggjMAE&url=http%3A%2F%2Fslink.intexdevelopment.com%2Fproifv%2Fproifv_dl_loadblob%3FEMTKEY%3D15617&usg=AFQjCNEp2w45MYXqkkb9Edb-Qi5XJ6-03A&sig2=vgHWvP
Jun 30, 2016 | Intex Pool & Spa
I have an Intex Ultra frame 18x48 with the salt water system, I haven't added salt in a while and keep getting a high salt alert and I add water frequently because of the evaporation (which is well water)....
When water evaporates, it leaves the salt behind. Depending on your well water, it may also already contain salt - adding yet more salt to your pool each time you top up...
Perhaps try emptying your pool (all or partially) & starting again - don't think the old trick of sticking a potato into an over-salted soup to absorb the excess (& removing it before serving, of course) will work on a pool!
Aug 06, 2013 | Intex Automatic Salt Water System for ...
I need to clean salt cell but not sure how i am suppose to that i need instruction on how to take apart to clean
The perfect place to look for answers to your problem is by going directly to the Intex website and they will answer this for you. Their FAQ Section can be found here:
INTEX FREQUENTLY ASKED QUESTIONS (FAQ)
Hope that helps!
Sep 09, 2011 | Intex Automatic Salt Water System for ...
How much salt do you put in a 22,000gal. pool?
WOW... You have a huge above ground pool! Are you planning to use the Intex chlorinator to chlorinate your 22,000 gallon pool??? If you are, take a look at the max gallon rating and how long you may need to run... Here's a chart that should help you determine how much salt to add... After adding the salt, run the pump for 24 hrs without the chlorinator to properly dissolve the salt... Don't be surprised if you need to add above 500 lbs!!!
Good luck and hope this works for you...
Aug 22, 2011 | Intex Automatic Salt Water System for ...
I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Lost manual
At initial startup add 290 pounds of salt. Add 75 pounds if low salt warning appears. Set the timer to run the pump for 10 hours per day.Get a downladable owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Lost Manuel
What size is your pool I could let you know how many pounds should be in there.
Most likely it would be easier to test your salt content. You need a 12 dollar test kit that has 10 tests in it. It is very simple just put an inch of pool water in a cup and let the test strip sit in it for about 5-7 minutes. Then read the results. Compare with the bottle #'s if too high then drain some water and add fresh if too low then add salt. ( your ppm should be as close to 3000 as possible) Keep in mind algae is due to lack of chlorine or improper ph and alkalinity not salt content. How often do you run your salt system? at 80degrees I run my salt about 4-6 hours a night and then switch it over too just filtering for 8 or more hours.
Also keep in mind that for a pool to be truely filtered it should be turned over at least 3 times so if you have a 5000 gallon pool and only a 2000gph pump it should filter for 7-8 hours. If you have any specific questions feel free to contact me
Jul 02, 2009 | Intex Automatic Salt Water System for ...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
301 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
