Question about Electrohome Archer Turntable Stereo System
Electrohome Archer EANOS300 vinyl turntable doesn't turn
Turns on, but turntable will not spin.
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
Hi. I have a Crosley CR40 mini turntable. When I turn on the power, the vinyl spins but when the needle is placed on the vinyl, the vinyl doesnt move anymore while the spinner underneath it is still...
It sounds like you have too much pressure on the tone arm. Check the underside for springs. You might be able to remedy the problem the old fashioned way. Tape a coin onto the top of the tone arm, as far to the rear as possible. This will eliminate some of the downward pressure onto the record.
May 07, 2011 | Crosley Stack-O-Matic CR40 Turntable
CD BACKSPIN
CD Mode does not react in the same manner as as Vinyl mode when you try to back spin. At the very least, you will only be able to go back a few bars. It's mainly used to set the Cue properly.
If you want it to back spin, you'll have to use the Vinyl mode.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 03, 2009 | Pioneer CDJ-800 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Need free owner's manual for a Detrola record player Model KM837
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Feb 22, 2009 | Audio Players & Recorders
We have teh truntable properly connected to the computer but the computer isn't recognizing the turntable. The turntable turns, but we get no sound through the computer.
hi, first you have to take a pre amp phono, or a mixer for your phono....to amplified the signal coming from your vinyl...please check first..tnx
Nov 28, 2008 | ION Audio Vinyl Recording Turntable
Electrohome Archer Turntable Stereo System Logo
279 people viewed this question
Top Electrohome Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Electrohome Audio Player and Recorder Expert? Answer questions, earn points and help others
