Question about Video Game Consoles & Games
When i turn on xbox 360 red light flashes 3 times over and over.
  • 27 Answers
Your hard drive is bad
Posted on Jun 15, 2009
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
3 flashing red lights
Did you try disconnecting it from the power for a few hours?
Apr 18, 2008 | Microsoft Xbox 360 Console
Tip
What to do if you have 3 flashing red lights on your Xbox 360 Console?
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
on Jun 12, 2010 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I soldered ana chip & tightened gpu chip. after switching on the set green light appeared for 5/6 sec. changing to 2 red lights. 2nd time only red lights came . Now it's not turning on.
1. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. For more information about ventilation, see the "More Information" section. 3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Mar 10, 2009 | Microsoft Xbox 360 Console
Xbox360 3 red lights
YOu are having problems with the three red lights right (red ring of death)? How old is your xbox?
Dec 12, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Flashing 3 red lights
The 3 flashing lights suggests that it's a hardware problem and you'll have to send your 360 to Microsoft for repair. Go on xbox.com and there is a link for repairs.
May 26, 2008 | Microsoft Xbox 360 Console
Console with 3 red flashing lights
iv noticed that my xbox started flashing red and froze so i turned it off immeditly and felt the connections in the back were really hot and my xbox was really hot so iv moved it to an area where it could get good ventilation and keeps cool. havent had any more problems turning red it blows out alot of hot air out the back it needs to breath.
Dec 23, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
