Question about Garden
Ex0451 spindle drive fault
Motor won't run
Tape spindles do not turn, but motor runs
Assume this is about either cassette or reel-to-reel tape and not DVD.
The symptoms you describe might be a clutch that is refusing to engage but is most commonly a worn or broken or contaminated drive belt.
Sep 09, 2015 | Televison & Video
Makes noise will not spin
Possible that the motor is slipping . This can be due to JAMMED spindle or shaft of the agitator. it can also be due to faulty belt, drive or fault in the motor. Manually check the free movement of the motor to confirm this or reset the assembly to free the movement,
Jan 17, 2013 | Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Washer will not spin
Possible that the motor does not run with the load and it can be due to fault in the motor, fault in the capacitor being weak, fault in the drive., friction on the spindle drive.
You can check for free movement and if so check or replace the capacitor.
Jan 15, 2013 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool wtw5700sw0 won't spin and motor hums
Please check the motor capacitor, use a capacitor in parallel to confirm. check the motor spindle and paddle for free run., Please check this link;
http://www.espares.co.uk/advice/washing-machines/a/7/1379/how-to-replace-the-carbon-brushes-on-a-washin.html
Mar 14, 2012 | Whirlpool WTW5700S
My Bosch Nexxt 300 series won't spin
Possible that there is no output to the motor from the control panel in which case the control panel is faulty or if you can check the voltage on the motor at the time of program start , then it can be confirmed on the motor failure, motor capacitor failure.Also check the spindle for free run in which case it which case it can be jammed.
Mar 12, 2012 | Bosch Washing Machines
The light on the dvd player won't turn green any more.I can't get it to play any more. If I did get it to play it would say bad disc the light is now yellow not red are green any more.
hi,
You dvd have problem with its spindle motor. Spindle motor is one on which the CD rotates. If the winding of the spindle motor become short this problem can occur. you can see the spindle motor in the center of the mechanism. spindle motor will not cost a lot. Just replace the spindle motor your problem will solved.
ok
May 06, 2011 | Cyberhome CH-DVD 300 DVD Player
Clothes are still heavy with water after the spin cycle.
Make sure that the washer is running at the desired spin RPM. if not check for failure of the belt, fault in the brake pad holding on to reduce the spin or a failure of the motor or the motor capacitor.
Only a good spin RPM will ensure that the clothes are dry with the high speed motion.
SO check this out with a good inspection of the spindle and motor drive.
Wishing you a Happy New Year.
Dec 31, 2010 | Washing Machines
Panasonic RV32 DVD player has an H07 error
This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry.
u may try new spindle motor
Nov 12, 2008 | Televison & Video
Cd player fault quick fix any one?
You can do a few things to see what may happen.
  1. Check the spindle height. The platters sometimes slip down the shaft, or the spindle motor bearing drops and the platter gets closer to the lens.
  2. check that the spindle motor has not become lazy and "poling". give it a few spins. then try to read a disc again.
  3. Clean the laser lens with a cotton wool bud moist with windex glass cleaner. Then "polish the lens with a dry one.
  4. the spindle motor top bearing is worn and the payer mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. More likely to happen at the start of a disc, because the disc is spinning fastest whilst reading the TOC.
A drop of light machine oil from a syringe oiler can help the bearing to spin an not produce the knock. Only a short term fix to give the motor a "lube". Once the oil leaches out of the worn bearing the problem will return. I have run motors immersed in an oil bath to rejuvenate them before... but better to replace it anyway if its suss at all. Good luck, You could bump my profile by giving me a "FixYa" rating for my sharing my "knowhow". Any problems check back with me here.
regards
Graeme.
Feb 10, 2008 | Audio Players & Recorders
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
