Question about Philips Magnavox 51MP392H Rear Projection Television
32inch magnavox screen red color only - Philips Magnavox 51MP392H Rear Projection Television
  • Philips Master
  • 3,459 Answers
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some
Here is a quick test....
Using your original remote go-to the
tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able t32inch magnavox screen red color only - 0667c5f.png up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 21, 2009
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Philips Magnavox 9P6040CI ? Alignment ?
you have to set up the convergence using the on screen pattern generator.
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
