Question about Freezers
Kenmore frig/freezer, light/power on, no cooling in frezer.
Freezer not cold, frig. getting warmer. Cleaned coils underneath. Turned
up cooling level, w/ no results.
  • 27 Answers
Looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Posted on Jun 15, 2009
Haier troubleshooting
Does it have cooling coils in the back... or underneath... that might need to be cleaned and vacuumed out???. That is a common problem.. Another thing, check to see if the door is sealing properly.. The next suspect might be the temperature adjustment mechanism that you've been adjusting..
Aug 07, 2014 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Ice cream not freezing hard
Ice cream needs to be at 10 degrees or colder to stay hard. Check your thermostat and move it colder if you need but give it 24 hours to stabilize to the new setting. Another thing you might check are the coils on the outside of your freezer. They will be on the back or underneath your freezer. What you need to look for is to see if there is any lint or dirt that might be built up on the coils. If they are real dirty they need to be cleaned off with a vacuum or an air hose if you have one. The dirt build up keeps the freezer from cooling efficiently and causes it to run warmer than normal. If all of that is clean and boosting the thermostat to a colder setting does not take care of it you might need to call a service tech. Hope this helps.
Jul 24, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Fridge wont cool but frezer is fine
looks like you have a problem with the damper control. try to locate the sensor for the damper control and relocate it, if still not cold, replace it.
May 04, 2009 | Freezers
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Freezer power problems
The on/off switch, power cord, outlet, based on the little info. I have, sounds like a power problem.
Dec 25, 2007 | Freezers
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
76 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
