Question about Hitachi 53UDX10B 53" Rear Projection Television
Red color is not aligning with the screen
The red color seems to bleed all over the screen. ON the left side of the screen it seems to dip downward and bend the red color rather than aligning. Please help.
Thanks.
[URL=http://img196.imageshack.us/i/1000738x.jpg/][IMG]http://img196.imageshack.us/img196/8030/1000738x.th.jpg[/IMG][/URL]
[URL=http://img196.imageshack.us/i/1000740lqo.jpg/][IMG]http://img196.imageshack.us/img196/2985/1000740lqo.th.jpg[/IMG][/URL]
[URL=http://img44.imageshack.us/i/1000742s.jpg/][IMG]http://img44.imageshack.us/img44/9132/1000742s.th.jpg[/IMG][/URL]
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 163 Answers
Use picassa software.........
Posted on Jul 17, 2009
The screen seems to have two of the same image, green and red.
Yes.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Skyassoc
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
Red color alignment problem
1) Whenever a rear projection TV has convergence issues, the
fix involves replacement of both IC's = STK392-110.......sub to
STK394-160E for improved durability...........
2) Soldering only is a temporary "fix" at best
3) Do not allow generic IC's, OEM quality or better = I use
Hitachi brand,made by Sanyo,with no callbacks....
4) Skill level needed = above average,....needs chassis pull...T.
Nov 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
KP-57HW40 rear projection TV colors out of alignment and warped
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2010 | Sony KP-57HW40 57" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
Three colors line up on some spots but not others
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Convergence problem or??
Yes it has power supply and convergence problem let me know if you need help with part # s or how to fix it
Jun 23, 2007 | Samsung PCN5425R 54" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
186 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
