Question about Sony Cyber-Shot DSC-S50 Digital Camera
Display stuck on Play Mode
Display is stuck on "Play Mode", and does not change when switch is change to "Still" or "Movie Modes" . It take some pictures after turn on , then it will not take any more although the sceen is on and the green dot indicating focus appears
    Scholar:
  • 89 Answers
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Posted on Jun 17, 2009
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Jan 24, 2016 | Canon PowerShot S3 IS Digital Camera
Video/movie mode stuck
Have you tried to reset the camera?
Reset switch is on battery compartment you will need a small needle or toothpick. Let me know if this works!
Jan 02, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Sony dsc-H1 won't switch off of movie mode
When you switch the camera from mode to mode, does it make the click noise to signify that the camera recognized that it changed modes? If not it could be that the switch itself has become unlogged from the switch. I know I had a older camera had this happen before. Try pushing down hard on the toggle wheel and seeing if it will snap back into place. Otherwise the switch inside the camera itself is probably broken, and if this is the case cheapest thing you can do is have Sony do warranty work on the camera. http://www.sonystyle.com/webapp/wcs/stores/servlet/SYCustomerCare?storeId=10151&catalogId=10551&langId=-1 Click repair and service under Technical Support. This will get the process started on the warranty work.
Aug 25, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
Won't play movie
sounds like the dvd is bad, try another dvd if that doesn't play then it is the player.
Nov 15, 2009 | Polaroid PDV-0700 Portable DVD Player
Onkyo Tx SR606 Listening Modes "Not Available" Via Optical I have my Sky+ Box plugged directly into my TV with an optical cable from Sky box to my 606. I had no problems changing the listening modes untill...
check to see if the DIRECT icon is illuminated on the panel...if so, cancel the DIRECT function. This is only a thought, also check HDMI settings as well as optical mappings...
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Digital camera
There is tiny place with the wrighting of "C1220" - pull it out and put a new bat. all be solved
Dec 15, 2007 | Cameras
Lens is not opening in the movie mode,unable to record movie also.
normally there are two possible causes for the problem, 1) the connectors of the rotary switch are dirty or not making proper contact. 2) the cable from the rotary switch is damaged. In both the cases you have to get the swith changed.
Nov 01, 2006 | Nikon Coolpix 3200 Digital Camera
Slider between modes (play,movie,stills) stopped working
Sorry, The only suggestion I can make is to give the Canon helpline a call on 08705 143 723 / or any other professional.
Oct 19, 2005 | Canon IXUS V2 Digital Camera
Changing the quality setting
There are three groupings of shooting modes on the C-725 UZ: 1) Program & A/S/M, 2) Auto & Sports & Portrait & Landscape, 3) Movie mode. Each group can retain a quality selection for all modes in the group. Therefore, you cannot have a different quality setting for each shooting mode within a grouping.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
Sony Cyber-Shot DSC-S50 Digital Camera Logo
56 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
