Question about Samsung Audio Players & Recorders
Wire less woofer is not working
PSWF450 stop working blue light is flashing but no sound
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Blue light flashes on sub woofer cant get sound
After you confirm that the audio signal is reaching the subwoofer, then either the amplifier or the woofer itself is defective. U can establish continuity across the leads of the SW - if ok, then check to make sure that the surround of the cone is intact. If sw passes the inspection(s) the the anomaly lies with the amp.
May 22, 2015 | Audio Players & Recorders
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
No sound from woofer behringer truth monitor b2031
first check woofer (end wire problem )
remove woofer from circuit
test with 1.5v battery cell touch parallel woofer lead neck
if disturbance sound come from woofer
woofer is ok
Apr 29, 2014 | Behringer Truth B2031 Other Dj Equipment
Sub woofer is not working. it has orange flashing light at the back
Look at the connection of the sub woofer. The orange light indicates either there is some problem with the wire or the connector at the end of the wire.
Also make sure the pin or hole where you insert the sub woofer is working perfectly. You can simply check it by placing another sub woofer at that vary spot and see if it is working fine. If the hole is fine then the problem is either with your cord or your wire pin.
Oct 24, 2012 | Audio Players & Recorders
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
No power
check the connection to the battery gnd an remote also check the wireing of your woofers because a wire load to low for the amp will make it jump also check for any corrosion on the battery post
Jun 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
One speaker fell ... no sounds ?? can it be
Most likely, if the LED is still functioning on the speaker, then an internal connection has simply come loose. If you use a screwdriver to remove the woofer (the large speaker) you will gain access to the inside. You should be able to both easily see the loose connection and reach it to plug it back in.
A little less likely, but also possible is that a part of the internal circuitry is broken. But, usually in those cases, the light stops working as well.
I hope this helps.
Oct 08, 2009 | Alesis Monitor One Mk2 Speaker
Woofer not working
hi..
sounds like the voice coil could be open or damaged. the woofer can be reconed. reconing replaces all the moving parts in the speaker frame returning to new condition in most cases.
thank u
rate me
Jul 21, 2009 | Alesis M1-Active MkII Main / Stereo...
63 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
