Question about Building Materials
Garador wont close
Electrical power close
Maytag bravos electric dryer powers on but will not run no codes on it, just wont run
Check that door is fully closed. Or turn on dryer and manually press the door switch to see if that works. If not than it is that switch. A thermoswitch will also do that
Mar 30, 2014 | Dryers
My garador auto m2 garage door only opens 3/4 of the way how do I sort this ?
There are limit switch settings for fully opened and closed positions. Check the fully open limit switch adjustment.
Sep 22, 2012 | Computers & Internet
Replaced the battery but the car wont start. The auto door locks wont work either.
You didn't indicate whether any other electrical parts worked or not, I will presume not. You should inspect closely the cables and make sure that both the postive and negative cables are good and not broken and connected. The large positive cable connects to the the starter solenoid. However the power for the other parts of the system will be a smaller cable that might have either a fuse or what is a fuseable link. You have to have an elementary electrical tester and testing capability to check for voltage to the fuse power block. If the main power circuit to the fuse panel is down, you won't have power to the door locks or other circuits including the starter actuator circuit.
Good luck
Mar 03, 2011 | 1998 Honda Accord
My dryer will power on, door is closed but will not start... the error code that comes up is "dr" like the door is not closed?
door switch, he is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 29, 2010 | Hotpoint TDL15 Electric Dryer
Dryer wont heat up
check voltage going to the heater,if no voltage check the contactor if energize,if not energize,close the power and check the thermostat with multimeter and test the continuity if the contact will close or open.
Jun 05, 2010 | Roper RES7646KQ Electric Dryer
When Checking resistance in a circuit open means electricity will flow or wont flow.and does closed mean electricity will not flow or does closed meanthere is alot of resistance
Think of a circuit as a circle. When the circle is closed, the electricity can make the complete way around. When it is open, the electricity is stopped. So an open circuit is not complete and the electricity will not flow, while a closed circuit will allow the electricity to come "full circle".
May 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Stove door wont close
try shutting off power and then turn on..If this doesnt work turn on self clean again ,start it then after a few seconds cancel. This should tell the lock to release.
Mar 30, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Electric trunk wont close
the electric pull down motor has gone bad and if I remeber correctly that motor is an integrate part of the latch assembly. Cple bolts and amn electrical connector and the repair is made. take about 25030 minutes or less depending on skill level.
Jul 23, 2009 | 1993 Cadillac Eldorado
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
The door on my asko w6021 wont close
Hello
Well I'm sure you have power on machine if not check fuse located at rear of machine below lip.
Next step remove top cover a cheap saftey screw driver set
will do trick not standard drivers.Electrical drawing is located
inside,Photo copy,now locate a cheap multimeter for testing,
don't worry it's not rocket science.Look closely at cables notice all cables have numbers printed.If PWR lamp above switch is on proceed as follows.
Remove power from machine & test on the Ohms scale between
E111 & E113 if you have resistance great i can't remember value! Now put a bridge wire between E121 & E111with closed door should lock when machine is turned on ,if not you can test between V Volt scale ac & you should read about 30 Volts ac Between E113 &E111when you press door release button on front of machine.
Note the switch LB in drawing represents front door you can also
check across this on Ohms scale with no PWR.
Regards
May 02, 2008 | Asko W6021 Front Load Washer
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
