Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Vertical line i have a dell 2005fpw now when turn on after about 20second after windows finish loading i get a whole lot of verticals down the screen, with of different colors. you can still see the image on screen it is still quite clear, although the center of the screen moves down to where the taskbar is as well of a whole lot of flickering. not to sure what the problem is. have tryed this monitor on two computers with the same thing result. so the problem must be in the monitor. any help would be greatful thanks.
  • 1153 Answers
SOURCE: dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Posted on Sep 14, 2007
SOURCE: vertical colored lines
I had the same problem with my monitor, saw only coloured vertical lines. I opened it, opened the back of the metal casing to get access to the circuits. There I found a loose connector. I reset it and it worked again!
Posted on Jan 23, 2008
  • 3940 Answers
SOURCE: Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Posted on Aug 09, 2009
SOURCE: Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Posted on Oct 10, 2009
Testimonial: "I don't know what a c637 is or how to replace it or the logic board and I can't find anyplace on the net that has instructions or even information"
  • 1768 Answers
SOURCE: I have a 2005FPW monitor that is rolling
1. you have a power supply issue. Possibly a regulator in the power up circuit and it has a weak component such as a capacitor and or a diode that is defective.
2, You will need a repair tech to look at the main board to determine which components need replacement.
I hope this helps. Have a great day!
Posted on Jul 18, 2010
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
Fuzzy screen and a vetical line
Could be a faulty screen or a GPU issue. I would get it exchanged for a new one.
Jan 19, 2014 | Dell Studio Computers & Internet
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
I had same problem.
Sep 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Vertical white line in center of monitor
Your monitor may have been cracked somehow...
Try restarting and look to see if the line is there immediately from the start or does it only show up when your operating system (windows/linux) loads?
Regards,
Chester
Jan 11, 2008 | Dell Inspiron 2200 Notebook
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
73 people viewed this question
Alun Cox
