Question about Bissell Cleanview Reach Carpet Cleaner
Bissell Cleanview Reach carpet cleaner leaking
Only used 3 times and now it's leaking water from the bottom when I refill. It's pouring out but I can't find any breakages
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: 9200 Bissell carpet cleaner, water will NOT dispense
My Bissell also STOPPED SPRAYING WATER.
I've owned a Bissell 9200 for a few months. I've used it twice, the last time most likely being around August. I attempted to use it this past weekend and it wouldn't spray. I searched all the help sites I could find and thought the solution was a clog in the heater, which many said was located in the arm. After I took the arm apart, to my surprise, THE HEATER IS NOT LOCATED IN THE ARM OF THE 9200 MODEL.
It's still under warranty, however am not located near a service center so I took it upon myself to try to fix it.
I'm just a single female who ends up trying to fix a lot of stuff herself so, I don't speak "technical instructions". But, here's what I did in the event that it may help someone else.
I unscrewed all the screws that I could on the base. I removed the cover over the motor. Doing so revealed the hoses attached to the soap dispenser. Located closer to the rollers were more hoses. On the same side as the foot lever, above the wheel is the where the HEATER is located.
Being that I was looking for a clog, I unclamped one hose at a time; inserted a safty pin into what the hose was attached to and wiggled it; re-clamped hose afterwards.
The only slight confusion may be with the screws. There are only two sizes. I used finger nail polish to mark where the small ones went.
I reassembled it, turned it on, and it actually started spraying again!!!!!!!!
So that this "blockage" won't occur again, I will take advice I've read about cleaning Bissell's hoses out after using it.
See, taking the thing apart was really nerve racking! Especially not knowing if it would even work after I put it back together.
GOOD LUCK WITH FIXING YOUR CLOG!....you'll probably need to sooner or later.
Posted on Feb 09, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
Need a user guide for a Bissell 1761 carpet cleaner
The only 1761 on the Bissell site is a micro-fiber floor duster refill (2 refills sold for $10). https://www.bissell.com/microfiber-floor-duster-refill-2-pack-1761?utm_source=legacyredirect&utm_medium=legacyredirect&utm_campaign=%2ffloor-duster-refill-2-pack-1761%2fparts . Bissell doesn't have a manual for the refills.
This is the refill for the Bissell 1763 microfiber Hard Floor Duster. See https://www.bissell.com/microfiber-hard-floor-multi-surface-duster-1763 . The instructions for this model are available on the page. The direct link to the instructions is https://www.bissell.com/~/media/site%20us/documents/user%20guides/1763/bissell_instruction_sheet_floor_duster_1763.pdf?la=en . These instructions only include the directions for adjusting the handle length on the duster.
I hope this helps.
Aug 05, 2016 | Bissell Vacuums
Brushes not rolling
You may have to remove the brush roller and disassemble it to remove hair and debris trapped inside the end caps.
Dec 07, 2014 | Bissell 22K7e Cleanview Lift Off Carpet...
Bissell 7920 ProHeat Upright Carpet Cleaner leaks soap
Just prespray with a pump up sprayer and use unit to extract only with hot water.
Apr 07, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
I misplaced manual for Bissell Bagless Cleanview II, nothing being picked up in the plastic bin, where to I look for clog other than bottom of hose near bottom plate please?
Recline the vacuum fully to the floor when looking for clogs in the lower hose. You can run a broom stick through the upper hose to remove any clog. Also, check the brush to make sure there is no obstruction. Lastly, make sure all 3 filters are clean and clear because if they are dirty that can restrict air flow drastically. You can purchase filters at www.bissell.com
May 29, 2011 | Bissell Cleanview Helix Deluxe Bagless...
An operation manual for bissell powermaster cleanview how to obtain a manual I need to know how to assmble the bissell powermaster also how use powermaster
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 06, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Cleanview Reach Carpet Cleaner Logo
146 people viewed this question
Top Bissell Home Experts
Lawrence Oravetz
ray gallant
Are you a Bissell Home Expert? Answer questions, earn points and help others
