Question about Amana ALE643RB Electric Dryer
Dryer runs hot and a little louder
I have a KitchenAid electric dryer, and for the last week it has run very hot, and you can smell the dryer like the hose isn't connected. The hose is connected and you can feel it blowing through the outside vent. It also runs a little louder, sounds like it it trying to push air. Please HELP.
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    have you fixed your problem?
  • 27 Answers
Sounds like the thermostat needs to be replaced
Posted on Jun 15, 2009
Kenmore dryer made couple soft pops, blew breaker and smelled very hot.
sounds like a wire rubbing on drum and shorting
Apr 06, 2014 | Dryers
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
Mid-tone loud hum while dryer is running. drum is turning...you can hear the clothes falling inside. They dry well. It is just that hum that came last week, and is now louder than it was.
HI- if everything is operating ok it could be that the dryer cabinet is just getting loose somewhere. When its running try pressing on the top, sides and back to see if you can get it to stop. There could also be something in the blower wheel that is causing imbalance and the hum. Less likely is a motor issue. Good luck
Sep 24, 2010 | Estate TEDS740JQ Electric Dryer
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
Sep 18, 2009 | Kenmore 62602 Electric Dryer
My smells hot and is putting off a lot of heat in
Vent pipe came off, most likely. I had same problem last week.
Jun 04, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Brand new Dryer with loud noise and hot
contact bosch for factory service on the unit
May 10, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Dryer smells hot
hi ,
run a load in fluff no heat and see if the smell develops again, if it does then I would suspect the motor or belt. generally most dryers are serviceable from the rear, the whole back panel usually, make sure you unplug it of course. make sure your not overloading your machine with clothes. It should never be more than half full ever. a slipping belt causes a burnout smell like when a car spins its tires at the races, if thats it you might need a new belt or your idler pulley may need to be bent a little so the belt runs tighter, study it
J
Jan 23, 2008 | Whirlpool LER5636P Electric Dryer
Kitchenaid prestige dryer model keys677EQ1
I have a KItchenAid Presitge Electric Dryer; Model #YKEYS677EQO. It just shut off. I tried resarting it but all I get is a humming noise. This humming noise only lasts for about a couple of seconds then I get nothing. The barrel can be turned manually.
Dec 15, 2007 | Dryers
Amana ALE643RB Electric Dryer Logo
56 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
