Question about HP Pavilion DV9930US 17-Inch Laptop PC Notebook
Hp dv9930us service manual
Parts
Servis manual
Service Manual can be downloaded From
http://www.eserviceinfo.com/download.php?fileid=10036
It is in 29 Parts after you have downloaded the 29 parts to a Dedicated folder, I named my HP 4500
You need to download 7-Zip and install it
Right Click on the first part and and select 7-zip and select extract t0 "hp color LaserJet 4500 and 4550 Service Manual"
If you did everything correctly you should see a inside that folder this PDF file "hp color LaserJet 4500 and 4550 Service Manual.pdf"
I downloaded it and verified that it is authentic and 58,802Kb in size
Site asks you for Donations, Use your own judgments on whether or not you want to donate.
May 05, 2016 | HP Officejet 4500 All-in-One Multifunction...
Service manual
All parts and full service manual may be located here:
HP Printer Parts and Service Manuals
Oct 27, 2013 | HP DeskJet 1125c InkJet Printer
We have a LaserJet 5500 in which a part is broken, no description or part number being available in service manual. It shows the part in figure 8-11 of the service manual, but no further information is...
There are some parts that are just not available period. I work for an HP service partner and I have had HP contact me trying to find some of these unlisted parts. Your best bet is to try and find a dead unit you can buy for parts, or check with a local service center if they happen to have a 5500 sitting derelict that they will canibalize a part off of.
Mar 14, 2011 | HP Office Equipment & Supplies
The computer powers on but the screen is blank. When I hook up an external monitor, it works fine. It's an HP dv9930us.
While the system boots, look at the laptop screen from a sharp angle to see if you can detect any imaging. If so, then either the backlight CCFL (fluorescent tube) or the high voltage inverter for it has failed. Neither of these are expensive to replace (check on eBay) and replaceable by a user with some manual skills and a few small tools. Replacement by a pro may cost somewhere from $100-$200 US.
Both of them are often located in the display portion of the laptop.
Jan 07, 2011 | HP Pavilion DV9930US 17-Inch Laptop PC...
Hi, My name is Joseph. My HP DV9930us is not displaying anything except some blurry light and when i connect it to an external monitor, it shows lines vertically. Anyone has a good suggestion for me. I...
Joseph, I've had this problem more than once by this laptop. Unfortunately this is a known issue and the only way to fix it is by sending it in. This usually indicates a motherboard / video display driver failure. Mine is still under warranty so I send mine in for repair whenever it happens.
Oct 20, 2010 | HP Pavilion dv9330us Notebook
I have a HP Pavilion dv9930us and its look likes a key is stuck on it. I want to replace the keyboard. Where do I start? i don't see any screw on it.
You will need a tork screwdriver to remove the screws. They are black and hard to see at times. Turn your laptop over so its on the screen and you should see them. Most times HP have keyboard symbols on the bottom to show you were the screws are.
Feb 24, 2010 | HP Pavilion dv4000 Notebook
Service tech seeks service manual in .pdf for hp laserjet 3330
Any HP printer. All parts diagrams:
http://partsurfer.hp.com/cgi-bin/spi/main
Apr 02, 2009 | HP LaserJet 3330 All-In-One Printer
Inverter part no
HP/Compaq Power Supply / AC Adapter, 120W (18.5V 6.5A), PPP017L PA-1121-12HC, 384023-001, 391174-001
Mar 11, 2009 | HP Compaq nc6320 Notebook
Internal Bluetooth Adapter won't work...
hi...
first what we need to check if the bluetooth software is installed or not,right click on my computer and go to properites,once you click on properties,click on the tab that says advacned and underneath this box you will see an option which says device manager,click on device manager and check if the bluetooth adapter is listed under the category that says bluetooth or network adapter,if you see that there is no yellow question mark under bluetooth option,if there is a yellow question mark then you probably need to reinstall the drivers...if the software is listed and yet it is not getting detected probably we need to reset the bluetooth adapter and also make sure if the bluetooth light on the laptop is on or not,the light is situated on the front of your laptop...
incase the device manager looks perfect then go ahead and reset the bluetooth card
link to download drivers for vista...http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56755-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3747258
here the manual that u can download to see how you can reset the bluetooth card...http://h10032.www1.hp.com/ctg/Manual/c01295898.pdf
vedhick
Feb 10, 2009 | HP (PH075AV) Bluetooth Wireless Adapter
HP Pavilion DV9930US 17-Inch Laptop  PC Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
