Question about Uniden Cordless Phone
Spurious emission - voice modulated - Uniden Power MAx2
Uniden phone FCC i.d. AMWUP320 generates a continuous , even when on-hook, spurious emission at 3.52 MHz which radiates for almost two blocks.  Voice modulation of both incoming and outgoing audio is present o this signal.  Is this normal?
  • 37 Answers
SOURCE: uniden tru8880-2hs
In standby mode, press the volume "up" key or volume
"down" key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Posted on Nov 07, 2007
One Wire
  • 126 Answers
SOURCE: checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Posted on Jan 26, 2008
  • 1952 Answers
SOURCE: need manual for uniden exa18580 cordless phone - 43k
Posted on Jan 03, 2009
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: uniden cordless phone manual DECT1580-2A
How can I put my own message on my Uniden DECT1580-2A when I'm not here to answer my telephone.?
Posted on Dec 27, 2010
  • 34 Answers
SOURCE: My Uniden Phone disconnects every 1 minute
there is a timer accidentally activated on it. please use manual, go to the menu and disable call timer.
Posted on Mar 05, 2011
0 characters
1 Points
Uniden cordless handet phones
Probaly cheaper to replace phones
May 18, 2014 | Uniden Phones
Re-setting voice mail indicator
You have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Sep 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
UNIDEN DECT 6.0 don't have manual need to
Select the model of your Uniden DECT 6.0 phone from the list beginning at
to get the manual.
Sep 01, 2011 | Uniden DECT 6.0 Cordless Telephone...
We have a Uniden DECT1588 Series system that we have just purchased. We are connected to a Voice Mail Service through Bell. We can receive the messages from the answering service but the light on the hand...
OK. You have a phone set with an answering machine, yet you continue to pay MaBell for Voice-Mail. Is there any compelling reason. That was my feeling when I first read your question but I thought you might not like what I had to say, so I consulted the Uniden FAQ and here what they have to say.
If you Uniden phone has a digital answering machine, and you also have voice mail through your phone company, the message indicator light will not light up when you have a message in your voice mail system. We recommend you discontinue your voice mail and use the Uniden internal digital answering system.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Phone ID
My mic doesn't work; callers can't hear me
I don't have the answer but have the same problem. Uniden tech support had me disconnect power, etc. to no avail. Next solution was "replace the unit". I'm looking for a two-line phone with no answering device - use voice mail. Any ideas?
Mar 14, 2009 | Uniden TCX905 Cordless Accessory Handset...
My handset displays "New Voice Mail" and the base displays 00.
This is the problem, thebase charge light flashes continuously,It says that I have a new voise mail and the the base says (00)
Mar 04, 2009 | Uniden Cordless Phone
My new Uniden Phone/Answer machine is loading down my fax line
I have searched the user manual and can find no help on this matter, although there are help numbers listed and I'm sure they can advise, here is the link to the main page and there is a link to a pdf manual download if you don't already have one
However, it may be that you could use a T adaptor or socket doubler on the line jack and plug both in. good luck !
Jan 03, 2008 | Uniden TRU8885-2 Cordless Phone
Uniden Voice Mail
Nov 29, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
124 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
