Question about Sanyo Video Cameras
Set date time
After date has been sethow do I reset for different time zone
SOURCE: date time setting does not program
For those having problems with having to enter the date/time everytime you start the EXILIM Z/S series camera .. the solution is simple - press the SET button once date is entered. I had this problem for 2 days .. couldn't figure it out. Then realised that I had been pressing the 'MENU' button once entering the date. This of course doesn't save the date and the camera keeps asking your for a date everytime you turn it on!
Posted on Jul 02, 2007
  • 374 Answers
SOURCE: Have to reset date and time every time I turn it on!
If you have to do that each time you shut it off and turn it back on try this. Take your memory card out and format your internal memory. Reset the camera and then re-enter the information. Shut the camera off and turn it back on and hopefully it will still be in there. If not then you have an internal memory error and that needs to be fixed by Casio.
Posted on Sep 10, 2008
SOURCE: cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Posted on Nov 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: I seem to be haveing
Digital watches all work from a memory chip on the movement. The most common problem is the memory is filled or corrupted when you cannot seem to re-set them. In most styles, pressing and holding all the set buttons in at the same time for three or four seconds can fix this error. The dial will clear and the time and alarms must then be reset. If not you may need to have a watch technician use the AC button inside the case on the movement. He will need to use a metal tweezers and touch the + side of the battery to the AC contact point on the movement.
Posted on Dec 24, 2008
LuckyJackson
  • 72 Answers
SOURCE: Setting Date And Time
Change to manual update only and this will allow you to enter correct time and date.
Remember to save and then revert back to automatic...if desired
Posted on Jul 04, 2009
How do reset the time
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Nov 01, 2015 | Pantech Cell Phones
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
Oct 06, 2015 | Polar RS300X Watch
How to change time and date on my pc
are running a Windows computer you should place the mouse pointer over the date/time, usually at the bottom right corner of your screen. Right mouse click on the date/time and scroll down to "adjust date/time" and left mouse click on that. A window will appear allowing you to reset the date/time. You can also change the time zone to your particular time zone. Some O/S will allow you to select internet time, which automatically keeps the correct time.
Jul 15, 2014 | Gateway Computers & Internet
Have just bought an Elonex ebook colour 705EB and been trying to reset date and time as they are wrong... done as said on Manual go into Settings choose Time and Date setting... change the date and time...
Hope you read this message. I just noticed your message today on this site.
I bought an Elonex 705EB for my mum and had the same problem. It's not pressing the select key that changes the time. You must correct the time then press Menu button on yes (I had to press twice in row before it worked). I don't know why it works different from the manual. I found this out through a lot of trial and error!
Jul 26, 2011 | Computers & Internet
Date and time changes but day do not change
This happens when the mobile phone has been set to automatically update the phone date and time. The phone may have been set to be in a different region with a different time zone from where you are and that has a different time.
All you have to do is to go to the settings menu and pick a time zone that matches your location. This should solve your problem.
Hope this was helpful? Thank you for using FixYa.
Jun 06, 2011 | Cell Phones
If the date and time is not same in the details in the text messages?
Usually it happens when the time zone is not properly configured in the phone.
Whenever the message is received the phone alters it according to the defined time zone in your phone's setting hence messages show different time than the actual.
For fixing the problem go to time and date setting of ur phone and select the proper time zone setting. I m from Pakistan so GMT+5 is the one for me. Select the one which suits your location.
May 24, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
I also have a Magellan Triton 300 and I can not change it to my time zone.. how can I change it?
From the user manual at http://www.magellangps.com/assets/manuals/MagellanTriton_300_400_500_UserManual.pdf
it says:
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
momentarily
Fundamentals
5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
Jan 02, 2010 | Magellan Triton 300 Handheld GPS Receiver
Set time zone initially when phone was first turned on, now can't reset time or date.
just go to settings and set the time and date and you will have the option in settings like zone time there you can check the zone and you can set the time.
Sep 17, 2009 | Nokia 5320 XpressMusic Cellular Phone
SHR-2082 RECORDING TIME ZONE FROZEN!
David,
try setting the time to something different (Like a day and hour from the current setting) than the current time and see if that come up if so then set the system to the current time and date and check again, if that solves your problem great if not reset your system and reprogram it.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Sep 27, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Video Cameras Logo
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
