Question about Craftsman 17 In. Dual Rear Tine Tiller
Model no. 917.297041 - transmission
Will not go in forward, stuck in reverse ?
2 Suggested Answers
  • 110 Answers
SOURCE: tractor will not go forward or reverse in any
Take that drive tire off again & make sure you replaced the key way in the axle to wheel. If this is missing the axle will just spin in the axle and not drive the tractor.
Posted on Oct 29, 2010
416 backhoe won't go in reverse, Where is reverse solenoid lodated
Early model 416's were mechanical linkage to the control spool. Later models added solenoids to shift forward and reverse. This has a block with solenoids on each end.
All models have a separate solenoid for neutralizer function control by the push button on the speed control shift lever and loader control lever.
They are different were as some used current through the push buttons for the disconnect neutralizer solenoid and later models use current through the push buttons to power the transmission shifter.
When a failure occurred in the neutralizer circuit or a push button stuck, early models only need to disconnect the push buttons to make the transmission work but, later models must have a jumper installed to bypass the push buttons and keep power to the transmission control lever.
Current models are all controlled by an ecm.
An easy test to see if the transmission solenoids (if you have them) is to place a screw driver tip on the end to see if it is magnetized when you place it in forward or reverse.
All models also have a front wheel drive solenoid but, it is located in different areas for different models.
Test the push buttons to see if you have one stuck. Then check the wiring to see if the circuit is the problem. If you have the electric shift control handle, check the fuse first, the inspect the wire and circuits. If this is controlled with an ecm, you can still check the shift control wiring but, to test the ecm, a service call to the dealer is needed. Some models did include a red light in the fuse panel area to indicate an active fault is in the ecm circuit.
Feb 02, 2018 | Cars & Trucks
Husqvarna mower forward/reverse pedal is stuck in the forward position. Engine runs but transmission not engaging. Cause-probably pushing pedal forward when cruise was set. How can I get it unstuck?
If this model has the CVT transmission, you should check to make sure the CVT is cleaned in the area where the CVT unit connects to the trans. This model has been known to collect debris and cause this issue. If not a CVT, check you return spring on the pedal itself.
Oct 29, 2016 | Husqvarna Garden
Vs auto have forward gears even in reverse any ideas please
A4LD stuck in forward, even while in neutral and reverse. - Ford ...
https://www.explorerforum.com/forums/showthread.php?t=216567
May 27, 2008 - 19 posts - ‎5 authors
I did find a thread that referred to an "always in a forward gear" A4LD problem, ... Eventhough band adjustment should not have anything to do with the .... in the transmission and then it auto shifts through the gears normally.
700r4 forward in all gears, even neutral, no reverse - Third ...
www.thirdgen.org/forums/.../631383-700r4-forward-all-gears.html
Oct 21, 2011 - 700r4 forward in all gears, even neutral, no reverse ... It has no reversebut when I put it in reverse it tries to pull the motor down like the rearend ...
my car is not moving forward or backwards even with gea
Dec 27, 2015 | Cars & Trucks
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
1997 chevy blazer transmission lunges forward in park,no reverse,and moves forward in nuetral
It can be issue with gears or problem with transmission and needs to be rebuild.Also get the tranny fluid checked. If its low,then such problems occurs.
To troubleshoot these types of issues,check the actual solved problems with these types of issues.There are solved help links provided below:-------Click the link below and go through the details and diagrams to troubleshoot the problem :-----2003 Lexus RX300: Transmission Fluid Burnt
Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
-----------2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
-------------2000 Toyota Camry: Transmission slipping and
Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission Shift Interlock will not
Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse, acts like it\'s in
neutral?
http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift To Reverse?
http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission, with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When Transmission is Shifted to
Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode Fuse number 27
blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Van wont go forward or reverse
check transmission fluid level and manual linkage adjustment if all is okay transmission could need over haul,sound like transmission has worn burned forward clutch plates damaged pistons or seals could have damaged roller clutch, oil pump faulty or stuck pressure regulator many things will cause transmission not to move in any gear.
Sep 09, 2012 | Chevrolet Astro Cars & Trucks
I have 2005 Chevy Suburban; when you engage the gear in drive the truck would move but won't get out of the first gear. I've checked my transmission fluid and its ok. It also responds to reverse when you...
Common problem probably a 4L60E transmission The low and reverse clutches are the same ones The forward clutches are another set and then there are the 3-4 clutches in another pack. So you probably burn out the forward clutches or could be a stuck valve in the valve body. Time for a transmission specialist.
Feb 02, 2011 | Chevrolet Suburban Cars & Trucks
F150 SUPERCREW 4X4 5.4L Got stuck in the snow and
sounds like transmission damaged. if forward gears are operational, suspect transmission failure. If nothing working ( either in 2 or 4 wheel drive) suspect transmission or transfer case.
Dec 25, 2009 | 2004 Ford F150
1999 F250 only goes in reverse, no forward gears.
I believe that reverse is operated by a brake band. So it seems to be stuck. It is operated by a piston, and the seal could have swelled and caused too much friction. But you could loosen up the adjustor so that it is disengaged, in order to get forward gears again. Perhaps you can force the piston to retract as well, once you drop the pan again.
Jun 26, 2009 | Ford F-250 Cars & Trucks
Craftsman 17 In. Dual Rear Tine Tiller Logo
69 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
