Question about Samsung Computers & Internet
My laptop samsung np450 r5e won't boot because i spilled water inside
It can not booting after water entered the machine inside so what should i do? thank you very much
Enquiry
  • 152 Answers
SOURCE: laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Posted on Nov 23, 2008
sands2499
  • 18 Answers
SOURCE: water marks inside laptop computer screen
Unfortunately this will be lost causesorry but you will need new screen try ebay
Posted on Mar 15, 2009
Preeth Tom
  • 129 Answers
SOURCE: my samsung laptop sens P20 display only stripes
HI
MY FRIENDS DELL STUDIO LAP ALSO SHOWS THE SAME PROBLEM.HE APPROACH THE DELLSERVICE CENTER
THEY TOLD THAT IT IS COMPLAINT OF DISPLAY . SO I THINK THE REASON MAY BE TTHE SAME SO YOU JUST APPROACH AN AUTORISED SERVICE CENTER
THANK YOU
Posted on Sep 12, 2009
  • 3940 Answers
SOURCE: spilled red wine on VAIO NR38Z laptop
Most likely, the fix will be a replacement palmrest and motherboard.
Posted on Sep 30, 2009
Sean80000
  • 1867 Answers
SOURCE: boot fills with water after heavy down pour
I would suggest that the rubber seals on the boot surround are in fact faulty or the boot lid is very badly aligned. (Has there been an accident repair to the boot area?)
1. Check the seals again - every inch - and check for movement as some of the rubber adhesive which glues the rubbers to the body work may have broken down.
2. You should be able to replicate the problem with your garden hose. Run the hose full bore over the upper section of the boot lid and over the rear window for a few minutes. As soon as the surface water has cleared the exterior body work open the boot and you should be able to detect where the entry point is by inspecting the edges of the boot compartment and the boot lid.
One person I know popped his wife in the boot while he ran water over the boot area to find a troublesome leak point. I would not recommend doing that.
Posted on Dec 05, 2009
Samsung np530u4c error boot
Tap F2 while powering up, enter BIOS and check boot settings order. Maybe it's become set to boot from CDROM first. HDDs should be set to AHCI formats. Try booting from CDROM anyway if you have an operating system on disk.
Jan 13, 2016 | Samsung Series 5 Ultra 530U4C - Ultrabook...
Power outage now my e machines el 1200 01h won't boot saying no boot file name revevied?
Try to enter your boot screen, usually by pressing F8 when booting up. Then go to your boot priority list and make sure it is booting from your hard drive. I'm not a fan of e machines, it is very possible that the power surge caused some memory or physical errors.
Apr 11, 2013 | E-Machines eMachines Desktop PC
Acer iconia coffee spill
Coffee Spill and it won't boot up? More than likely you have shorted out the motherboard and it will need to be replaced. Coffee is sticky too so there might be other damage components inside.
May 13, 2012 | Acer Iconia Tab A50010S32u Notebook
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
Water spill on keyboard
Remove the battery immediately,remove the water and place the laptop in a warm dry place for a day or so until it is completely dry.
When you replace the battery and boot up the laptop, hopefully no damage is done.
Aug 14, 2011 | Toshiba Computers & Internet
My Samsung R530 won't boot, just shows blue screen of death on startup, states "A problem has been detected and Windows has shut down to prevent damage blah blah blah Unmountable_boot...
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 12, 2011 | Samsung R530 Notebook
Dell Inspiron 14R Laptop. Daughter spilled liquid on keyboard and now when i turn on laptop screen says: For Atheros PCIE Ethernet Controller v2.0.2.3 Check Cable Connection! PXE-MOF: Exiting Intel PXE...
Ya sounds like the hard drive has died or there is a interface problem since you suffered from water damage. you may be able to get data off the hard drive by using a external hard drive connector but it may or may not work.
Mar 20, 2011 | Dell Latitude D600 Notebook
Spilled icetea on to laptop keyboard, will power up but nothing else screen is black. hp nc4200
Ugh, sorry you had the accident, but many a laptop has survived such a spill (or in my case spills) and booted to tell the tale.
I'm assuming you now have the machine powered off, if not shut ot down immediately and do not try to restart it until you have done the following. There is kind of a standard procedure for laptop spills that I will provide you.
The suggestions below assume that your nc4200 is no longer under warranty.
Remove anything attached to the machine, battery, cables, external drives, anything. Using a soft, slightly damp (yes damp - got to remove as much of that sugar as possible) cloth blot any liquid on the machine gently, do not rub.
Tilt the laptop gently from side to side to allow any possible liquid to drain out. Do not shake the laptop. The Place the laptop upside down so that any potential remaining liquid will drain out. Hopefully you did not spill this amount of tea 8^).
Secure a regular hair blow dryer. Set it to low and slowly move it back and forth over the keyboard from about six inches and do the same for the rest of the machine, focusing attention to the openings that it has for ventilation. Do this for about five minutes or so.
Now the hard part: Set aside the machine in a warm (not hot place) and wait (at least four hours and if you can wait overnight, even better).
Try booting it with nothing attached. If it still doesn't boot the problem has gone beyond the keyboard and you'll have to consider having it professionally serviced.
Good Luck and thanks for using Fix Ya
Mikeyaf
Mar 17, 2011 | Computers & Internet
Water spilled onto laptop and now its not booting up
Water spills are almost always fatal for laptops. Try this. Pull the battery out. Wrap the laptop in paper towels,put the laptop in a bag of White rice for 24 hours. Then plug the laptop in without the battery and see if the light is on the ac adapter. Turn the laptop on and check the light again. If it doesn't work you will need to replace the keyboard and motherboard. This is usually not worth doing on older laptops.
Jun 04, 2010 | Computers & Internet
Toshiba R100 Laptop keyboard won't work
Water might have had damaged the keyboard.
Solution, get a new keyboard and replace it....or
get a USA regular desktop keyboard, plug it into one USA connectors, and use it.
It will work too
Please don't forget to rate if this answer helps you.
Jun 23, 2009 | Toshiba Portege R100 Notebook
Computers & Internet Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
