Question about Water Rower Exercise & Fitness
My belt has snapped what can I do
Whilst rowing doing my usual routine. The belt snapped
2 Suggested Answers
  • 1455 Answers
SOURCE: serpentine belt snapped 2 days
A burning belt usually indicates a seized idler pulley on those gm cars. You will have to find which pulley is seized and change, it before replacing the belt or the new belt will only burn and snap again.
Posted on Sep 23, 2010
Why does belt to alternator keep skeaking + snapping?
Bad bearings can usually be detected simply by turning the unloaded pulley (wheel). They feel sort of gritty compared to a good bearing. The squealing and snapping is a concern, however. My best guess would be a belt tensioning issue. Squealing is usually caused by belt slippage due to an unusually loose belt. This leads to belt damage and eventually, breakage. Of course a bad idler pulley bearing or other defective component (A/C, P/S, Alt) can cause the same results.
Jan 25, 2016 | 2002 Mazda Protege
Tip
Battery light is on whilst driving
If your battery light is on whilst driving and your battery goes flat then their could be one of two faults you need to look for.
The first and most likely cause is that either the fan belt has snapped or if you have a squeling noise then the chances are it just needs adjusting.
If how ever the belt is fine and isnt slipping then this would indicat that the alternater isnt charging the battery properly so this would then need replacing.
on Dec 07, 2009 | GMC Canyon Cars & Trucks
1996 Infiniti i30 what could cause yhe power steering belt to snapped off
The belt was probably damaged due to wear and tear. The belts should be inspected and replaced routinely.
Mar 10, 2014 | Cars & Trucks
What mileage should the timing belts be change not showing any problems but itis a second hand car 1993
Manufacturers usually recommend between 50 000 to 60 000 mile between timing belt changes, although some are as low as 30 000 miles. It is the safest to contact the agents and find out what what the recommended belt life for your vehicle is. Belts seldom show any problem before just snapping and causing considerable and expensive damage.
May 03, 2011 | 1993 Toyota Camry V6
Serpentine belt snapped 2 days in a row, the belt was burning the other day but today it just snapped and my anti freeze started to come out
Sep 23, 2010 | 2001 Oldsmobile Aurora
Kettler Model Kinetic S3 Rowing Machine rope snap want spare rope
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183 e:mail:info@kettlerusa.com
Feb 15, 2010 | Kettler Rowing Machine Kadett Rowing...
HI Paper got jammed whilst printing, retrieved paper and message now reads See trouble shooting and routine mainenance Chaper in users guide what do I do now do not have manual to hand
if the paper is fully out if not then check there might be a small piece stuck on the sensor,try to check the sensor actuator may be misplaced it usually black in color try to fix it properly so that it moves freely.
Oct 20, 2009 | Brother DCP 115C All-In-One InkJet Printer
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Exercise & Fitness Logo
24 people viewed this question
Top Water Rower Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Water Rower Exercise and Fitnes Expert? Answer questions, earn points and help others
