Question about Sport & Outdoor - Others
Cold weather starting
Fires but willnot keep running
  • 6 Answers
SOURCE: fuel pump not running only in cold weather
how cold is it? below 32 degrees any water in your fuel will turn to ice the particles could clog your filter or freeze in the line try adding adding liquid heet its isoppropyl alcohol it will help
Posted on Jan 14, 2009
SOURCE: cannot start my 1988 dodge ram 50 in cold weather
You should buy one of the manuals for this truck (their very cheap on ebay and they are very helpful on all kinds of little tricks, I think I got mine for like $1-2 or so
For my winter driving/summer driving I have completly different setups for my s.a.s. and fuel mixture (richness) screw and have very little troubles (live in MN)
Posted on Apr 01, 2009
  • 8909 Answers
SOURCE: 1996 Suzuki Intruder 1400 hard to start and runs
Check the ignition system and set up the carb/s.
It sounds like the fuel mixture is too weak which could be a blocked tickover jet and/or the ignition system has a problem. If it is using a set of points, change the capacitor and check the points gap. If it is electronic ignition, check the ECU.
Hope that helps.
Posted on Dec 09, 2010
  • 44284 Answers
SOURCE: Won't run when cold weather
run fault codes and look for MAF/MAP/VAF sensors and ambient temp sensor as faulty.
Posted on Feb 22, 2014
oilyspill
  • 3641 Answers
SOURCE: Will not start in cold weather. Battery checks out ok. Will crank but not start. If battery booster is used will fire right off and run good. no computer code.
Your year--make--model didn't post for some reason? It makes it hard to look anything up.
Use a digital multimeter across battery posts, no jump, have helper crank it, how far does the voltage drop? Generic info says it shouldn't drop below 9.6 volts.
With engine cranking, all vehicle systems get battery voltage. Engine running, systems get alternator voltage, that is usually several volts higher.
There could be a voltage drop on the wiring or cables?
You can always check the basics, have helper crank it while you check for spark at the plugs, where applicable. If spark everywhere, use a gage and check proper fuel pressure and injector pulse.
Posted on Jan 07, 2016
Cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
Nov 21, 2015 | Cars & Trucks
Kawasaki fs730v willnot start in cold weather
check condition of the battery, check the ground at the battery and the frame connection. will it start in warm weather?
Feb 24, 2015 | kawasaki Motorcycles
My 1991 plymoth colt gl wont start in cold weather
look at the ignition bypass resistor. It's on the firewall close to the brake master cylinder. It provides full battery voltage while cranking and then runs at reduced voltage the rest of the time. Your ignition switch controls it's operation, so look for a faulty ignition switch too.
Jan 24, 2014 | 1998 Toyota Tacoma
Turn the key and it will not start
cold weather kills batteries this time of year...heres why..most batteries are a chemical factory..the acid and water separate as the battery discharges..also the chemical process is lessened when the air temps go below freezing by around 50% or more depending on the age of the battery..in extreme cold areas, external heat sources are required to keep engines warm enough to run..in alaska for example,the batteries are taken out entirely and put inside to keep warm..sometimes a fire pit is used to warm the engine from below (red hot coals no flame)..also in very cold weather, the engine oil will get very thick..in some cases the oil will actually glue the engine semi solid..locking it up..if its a cheaper oil that whathappens..I like 20 miles north of st louis in illinois and when it gets below 30 degrees outside i place a under cabinet 350 watt heater(used for keeping food warm to serve) upside down under my engine overnite..this keeps the block warm and the oil thinned out..and works very well for me..my car will start whe no one elses will in my neighborhood..hope tyhis helps you..
Feb 09, 2013 | 1991 GMC Sonoma
I have a 1999 Chrysler Cirrus. I drove it yesterday with no problems at all. I go to start my car this morning and it wont start. Its turns over just fine it dont even sound like there is a problem but...
try the spare key in case its the chip in the key playing up for whatever reason if spare key doesnt work then check to see if the immobilisor light is on ,Now also of course if the temperature is too cold what can happen in extreme circumstances is a micro chip malfunction where they fail in the cold and if this is the case then push car into teh garage and let it warm up gently and it should start ,been getting this a lot with other things as well because of the cold and cheap chinese micro chips so your not the only one.Also keep car keys away from any electro magnetic source like tv screens and body scanners magnets and most of all a tesla induction battery charger ,be surprised how many people try to recharge their remote car keys on o0ne of these type of charger .
Feb 10, 2011 | Chrysler Cirrus Cars & Trucks
5.7 Hemi won't start in cold weather.
Cold weather makes the engine hard to start for two main reasons. First, oil thickens when it's cold, which increases friction and makes it harder for the starter motor to spin the engine. Cold also slows the chemical reaction in the car's battery, reducing its power output. Battery output is usually rated at 77°F, below which starting power drops drastically.
You can ensure that your car will start in the worst weather by keeping the engine or the battery, or both, warm.
You may want to consider a trickle charger for the battery to keep the chemical reaction working and an engine block heater to make it easier for the pistons to move freely.
Jan 10, 2010 | 2004 Dodge Ram 1500
The 2000 mountianeer starts and runs fine but shuts off
CHECK THE COLD START ENRICHMENT VALVE AND OR THE IDLE CONTROL VALVE. I AM ASSUMING THAT YOUR VEHICLE IS FUEL INJECTED. ONE OF THOSE HAVE GONE BAD.
Jan 24, 2009 | 2000 Mercury Mountaineer
Sport & Outdoor - Others Logo
26 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
