Question about Bosch B22CS30SNS Linea 300 Series Counter Depth Side by Side Refrigera
Clean heat dispersal fins
I can'y find any instructions on how to clean dust off the heat dispersal fins or whatever this fridge has. It's five years old and must need to be done. Older fridges always had a black radiator on the back that had to be kept free of dust etc
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
There is a good chance it is located behind a panel in the back where the compressor is located. The other location would be underneath the refrigerator behing the front grill. A vacuum and brush will do the job.
Posted on Apr 13, 2014
  • Jim DOwnes
    Jim DOwnes Apr 13, 2014
    Thanks for the suggestion. You are the only one. Unfortunately, this fridge doesn't have a front grill so I guess it's behind the back panel.
How do I clean the coils?
One of the best ways to clean the coils is with a shop vac and a coil brush. A coil brush is a cylindrical brush 1/2" to 3/4" diameter with a long flexible handle.Schaefer brush makes a good coil brush or a bottle brush duct tape to along handle will work in a pinch. The fins can be fairly fragile so use care in cleaning them.
Hope this helps
HTTPS:// Schaefer brush.com
Sep 22, 2015 | Freezers
My ice maker does not work
Hi there one of the biggest reasons for not getting cold which will affect the ice maker also is -- low or no air flow.
2 areas - 1) inside the freezer section are vents and they should have some clear areas (our freezer often gets crammed full of stuff)
2) under and behind the fridge is a dust bunny breeding area - pull the fridge out and get as much dust and stuff off the coils as possible (I use a vacuum and a small paint brush). The coils transfer the heat out of the fridge like an air conditioner. Be gentle - coils are somewhat fragile.
Some fridges have a faceplate that pops off at the front.
Sep 19, 2014 | Pragotrade 83-4020-W Weston 18In Frezer...
How do I get the open door chime to stop on Kenmore Fridge?
I had this problem also. My problem was that the drainage tube that keeps the refrigerator compartment dry was plugged up with the foil backing used in the freezer compartment. This foil backing is used to line the closed cell foam which insulates the defrost heat fins from coming in contact with the plastic back panel. It took a service call from a local repairman two times to unplug the line. We peeled off the foil lining which was the source of the plug.
This solution stopped the "door open"/"instant freeze" cycle sound. My fridge is about 6 years old.
Hope this helps. Best wishes!
Jul 23, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
Mar 05, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Problem with hussmann chest freezer
If the freezer is not located in an area where grease vapors are present the unit can be cleaned off using a vacuum cleaner. Then use a flash light to look through the coils. If you see dust embedded deep inside use a small air compressor to blow out the dust. Dirty condenser coils raise the pressures and temperatures in the system. Cleaning the coils and scheduling them to be clean at quarterly intervals should keep it functioning for a long time. Operating with a restricted condenser takes its tole on the compressor life span.
Sep 01, 2008 | Hussmann Freezers
True Fridge Running Hard
I would try this: unplug unit and use a vacuum cleaner and vacuum out the entire area. Not sure what you mean by "running really hard"? If you mean noisy, then see if you can see source after cleaning. Try this and let me know if I can be of any further help.
Jun 08, 2017 | True 12 cu. ft. / 340 liter Commercial...
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Hotpoint Mistral frost free fridge freezer.
This is a little hard for me to understand being a yank and all. 0C is 32 Fahrenheit, right so 4/5 is about 40? make sure everything is working, compressor , evaporator fan motor (the one inside) condenser fan motor (the one outside) if you have one. You should have an adjustment for freezer and one for the fridge sections, right. The fridge section controls what amount of cold air comes from the freezer compartment. Check the vents inside, make sure they are not blocked and they open and close when you adjust the control. If this all checks good then check the thermostat. If the compressor shuts off prematurely, then a new thermostat may be in order. If you think you can do this, find the thermostat, by-pass the wires. this will make the compressor run continuously. After 20 minutes or so it should make the desired temperature or close to it. None of the fans or compressor should turn off while this is by-passed.
Dec 31, 2007 | Freezers
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Bosch B22CS30SNS Linea 300 Series Counter Depth Side by Side Refrigera Logo
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
