Question about Panasonic Microwave Ovens
My Panasonic 1300 inverter microwave counts down to cook but then shuts off without actually cooking
Think I need to change a safety switch but don't know how
  • Official Brand Answer
  • 350 Answers
We don't recommend customer's attempt to repair products themselves. However, if you are going to attempt the repair we recommend you call 800-833-9626 to obtain the unit's service manual.
Posted on Mar 26, 2014
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: microwave not cooking
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
Posted on Nov 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: The touch pad works, the
http://www.microwavedisplay.com/doorsw.txt
Posted on Nov 26, 2008
WHAT DOES THE MESSAGE P10 MEAN
Most of the time P relates to Power. Microwave cooking Power at level 10. P10 is most likely the highest cooking power setting. If this is in error - Google the information - Or youtube it..
Aug 05, 2014 | Panasonic Black 1300-Watt Counter Top...
Microwave door alignment is off, will count down but won't cook
My microwave will not heat up its in a defrost mode. How do I change it?
Jul 27, 2013 | Sharp R-1505 Microwave Oven
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work fine, and the light inside turns on. We can enter a cook time, and it counts down as if...
It's one of the micro-switches (3) that are part of the interlocking safety circuit. I actually took my switch apart and fixed it, but 99% of those out there would (and should) replace the switch.
Dec 28, 2008 | GE JVM1330BW/WW Microwave Oven
Oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Microwave not cooking
Nov 21, 2008 | Panasonic NN-T990SA Microwave Oven
I have the Panasonic "The Genius" 1300 w microwave. I can not get it to work properly. When I push the time to cook then start, the light comes on (no sound from microwave) the timer goes down...
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In this case, it's probably happening because it;'s not cooking due to a switch problem.
Aug 17, 2008 | Panasonic Microwave Ovens
Frigidaire won't run
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Timer will run, but won't cook
Microwave Ovens Logo
37 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
