Question about Franklin Freezer Chef FIM70 Commercial Ice Maker
Not making Ice
My FIm70 does not produce ice sounds(makes a buzzing noise) like compressor is coming on but fan does not turn. both fuses in control box ok
  • 884 Answers
Are you getting any heat from the condenser? Sounds like the buzzing is the compressor failing to pump.
Posted on Apr 26, 2014
  • 1252 Answers
SOURCE: I have the franklin chef FIM70 ice maker and it
http://kitchen.manualsonline.com/manuals/mfg/franklin_chef/automatic_ice_makers.html
Start by checking out this manual on your machine. After that, get back to me and we can go from there.
Posted on Dec 30, 2009
  • 389 Answers
SOURCE: Our FIM90 will not make ice
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 10865 Answers
SOURCE: I have 3 FIM70 ice
Hello. The symptoms you describe indicate that an interior cleaning is in order:
The ice storage bin should be sanitized occasionally. Clean the bin before the ice maker is
used for the first time and reused after stopping for an extended period of time. It is
usually convenient to sanitize the bin after the ice making system has been cleaned and
the storage bin is empty.
1. Disconnect power to the unit.
2. Open the door and with a clean cloth, wipe down the interior with a sanitizing
solution made of 1 ounce of household bleach or chlorine and 2 gallons of hot water
(95? to 115?F).
3. Rinse thoroughly with clear water. The waste water will be drained off through the
drainpipe.
4. Reconnect power to the unit.
Here is the owner manual in case you do not have one:
http://dl.owneriq.net/2/294a2d80-17c5-43dd-ae8c-800510870f66.pdf
Joe
Posted on Oct 14, 2010
  • 1456 Answers
SOURCE: Franklin chef ice maker fim70
Hello
Ice may jam up in an ice dam and close off the chute. Shove the ice scoop up into the chute with a fair amount of force to break up the ice dam. Chunks of ice should fall into the bin, followed by a shower of ice cubes.
Posted on Jun 21, 2011
reyjoshua07
  • 1157 Answers
SOURCE: My FIM70 will not produce
Hi jerisaab,
If the unit won't produce ice, it is often caused by a bad water supply to the unit or a bad water valve on the unit. The easiest way to correct this is by disconnecting the water supply. Now if you have a strong water supply coming from the water line then replace the water valve, if not then replace the water line. You may also check if the circulating fan is working. If they stuck, use a WD 40 then work it back and forth a little.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 25, 2011
Why would a Franklin Chef FIM70 ice cubes melt before next ice drops
Its seems low refrigerant issue kindly contact with your local repair man to refill refrigerant gas
Jul 22, 2016 | Franklin Freezer Chef FIM70 Commercial Ice...
KM450MAB my machine makes a batch of ice then goes into harvest cycle and dose not come out of it, it gets realy hot. What can be the problem?
Probably the suction line thermister, this sensor should signal a timer in the main control board to initiate harvest. If the thermister is OK than there may be a problem with the control board
Nov 20, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer model FCF88W when started up for the first time it sounded like it was gurgling. It gave the impression that water was running Setting is on number 4 for initial start up and the unit got up to...
well i hope when you got this unit and put it in the place were its going to live in for its life you let it stand for a good fuw hours before you powerd it up??? thay need to stand to let the compresor oil and freezer gas find there way to the bottom of the unit,,,if not,,,well naughty you!!! smack your legs!!
but dont worry about the noise its normal for it to gurgle,,,,its the freezer gas being pumped around the unit,, if its freezing its working ok,,and not that it is you can run it at were ever you like,,,up to flat out if you wont to make ice sheets for mountains????
and by the way some times mine sounds like a very hungry hippo,,,especilally in the middle of the night,,, and it keeps me awake!!!
Jun 27, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Our FIM90 will not make ice. it worked when we got it and since then only produces cold water
Mar 11, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
My maytag Wide by Side refrigerator started making this buzzing noise coming from the freezer section every few minutes and now it no longer cools.
It is possible that the door was not closed tighly, so the humidity built up in the duct line and the low temperature from the freezer make it turned into ice causing the clogging. The Buzzing noise turns on due to the sensorsomewhre along the disigne path. Unplug the fridge for a day and a half so the the ice in the duct line could melt down then when you turn on the sensor won't turn on the buzzing any more. Good luck.
Jul 04, 2009 | Maytag Freezers
Ice Machine FIM600 Ice is making too big
remove front cover to view control panel. there is a cube size adjustment there. use a small screwdriver and turn it counterclockwise to make the cubes smaller
Jan 07, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Franklin Freezer Chef FIM70 Commercial Ice Maker Logo
141 people viewed this question
Top Franklin Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
AJMAL KHAN
Are you a Franklin Freezer Expert? Answer questions, earn points and help others
