Bosch Nexxt 700 Series Washer round front access panel how to remove
  • 1294 Answers
SOURCE: Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Posted on Dec 21, 2007
  • 130 Answers
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Posted on Jan 24, 2009
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
Posted on Jun 25, 2009
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
Can i stack the nexxt 700 series machines?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 10, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Nexxt 700 Series Washer, water from cold supply does not dispense into detergent tray
Make sure that the cold supply is on and/or the supply hose is not crimped or clogged. Other than that it can be a control panel issue in the unit itself. But first eliminate the basic things.
Mar 25, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Apr 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Is there a filter that I can clean out located behind the round cover on the lower right front of my Bosch Nexxt 500 series washer?  If so, how do I get the cover off?
just pop it off with a small srewdriver and yes you can get to the fluff filter through the round cover
when you open the filter there will be about two litres of water come out beware
Jan 21, 2009 | Bosch WFMC 3200 Front Load Washer
BOSCH washer, the door won't unlock and is reading E:04
I used a thin screw to release the lock through the access hole and this released it after rotating the round panel a bit. The manual release on my Bosch is a nylon deal that hangs down from the top. Just pull down lightly and open door. You may have to reach up past the drain to get a hold of the nylon string. The access opening is fairly sharp.
Dec 05, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Not draining
Clean out the lint draw and then run vinegar through a cycle.
If this doen't work try CLR. or/and put the drain hose to the lowest level and then put a flexible clear tube down to unblock it.
Use less detergent in the machine. I make my own detergent and I don't have any problems as one of the ingredients in it help keep all lines clear.
If that doesn't solve the problem contact Bosch directly.
Jan 08, 2008 | Bosch Nexxt 700 Series WFMC6401UC Front...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
