Question about Ryobi Tools & Hardware - Others
Ryobi Belt sander drive/alignment problem
Ryobi belt sander model BE321: could not get belt to track. it ran about 3/4" our from housing and stayed there. at about the same time the sander started jumping as if the timing/drive belt were skipping cogs on the drive pulley. Replace the belt. Sander ran less than 5 minutes and belt quit moving even though motor was running. Removed drive pulley. It was wallered out so that drive shaft was spinning inside of it. Replaced pulley with new one. Very soon the sanding belt started running off again and sander started jumping as if timing/drive belt was skipping. Sander was very hot on bottom - housing, rollers, sanding belt, etc. Suspect something wrong in sanding belt alignment mechanism, causing strain on rollers, pulleys, etc. If so what's the fix? Or any other ideas?
  • Bill Wallace
    Bill Wallace Mar 25, 2014
    It's obvious that none of the responders are familiar with the Ryobi BE321
cloe2594
  • 29 Answers
SOURCE: Dremel belt/disc sander
see the manual
Posted on Nov 06, 2008
mikeymiddles
  • 58 Answers
SOURCE: Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Posted on Jan 08, 2009
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
  • 384 Answers
SOURCE: Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Posted on Jun 12, 2009
SOURCE: Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Posted on Jul 11, 2009
I am having trouble replacing a belt on a Ryobi 3x 18 belt sander. it keeps flying off when I turn it on. am I missing a step or just not doing it correctly? signed....clueless about power tools'
the end roller is not aligned correctly
there is a screw adjustment that you move to realign the roller to make the belt stay on
all of the information will be in the user manual
Jan 24, 2018 | Ryobi Tools & Hardware - Others
How do you adjust the belt tension on the Ryobi BE321 belt sander?
Usually there is no belt tensioner on by sanders. Only alignment adjuster. Must use exact size belt.
Jan 06, 2015 | Ryobi Tools & Hardware - Others
Need a manual for a mastercraft 55-3554-4 sander
If you find best disc snaders in 2018, easy to assemble, easy to use go to the link Best Disc Sanders For Sanding In 2018
Dec 20, 2013 | Ryobi Mastercraft Belt/disc Sander Belt...
I have borrowed a ryobi industrial belt sander, I have put the sanding belt and repositioned the latch. When running the sanding belt keeps moving out.
There will be a tracking adjustment somewhere, usually a knob or wheel located at one end (axle) of the sander that allows you to adjust that... run the sander at low speed while you turn it until it tracks straight
Jun 10, 2011 | Tools & Hardware - Others
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
My Makita 9901 belt sander is used but very slightly and now is just frustrating to even use. What is the most common cause for tensioning roller to keep pulling the sanding belt over against the housing?...
There is a screw that changes the angle of the roller to change the tracking of the belt... this is very sensitive and probably if you are having trouble is more a reflection of the belt quality then the sander...try different belts before you toss the sander... I have had one for years and love it... although the belt tracking is tricky sometimes anss your have to keep after it...
The adjust ment is very touchy only turn it maybe 1/8 turn at a time...
heatman101
Aug 31, 2010 | Makita Tools & Hardware - Others
How do you replace the drive belt on a ryobi type be321
I tried the model number and can't find it on their site, but if this is a belt sander or planer you can "roll" the new belt in place without loosening anything. If this is another tool let me know and please give me all the information (tool type) and I will check further.
Aug 23, 2009 | Ryobi Tools & Hardware - Others
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Tools & Hardware - Others Logo
98 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
