Question about CAS lp-1000n label printing scale
PLU problem i have a LP-1000 v1.6 I have program all PLU through LP-work. i am sure the PLU are in the scale's memory. but i cannot call up the PLU using the scale.
I created a barcode & used PLU programs 100/200/300 to register it with my ER-380M. The barcode works ok with Price Enquiry but if scanned for a sale brings up a "Scale Error". Where did I go wrong ?
It sounds like you set it as a scale PLU so now it is trying to check the weight of the product on your scale. Set it as a non scale PLU
Apr 19, 2017 | Retail Supplies
AVERY BERKEL G220 SCALE SHOW E 5. WHAT DOES IT MEAN?
Error codes:
E 5 Disconnect then reconnect the scale to the power supply.
E 10 Battery failure.
E 11 Power supply voltage is too high.
E 15 Contact your authorised service agent.
E 20 Weight error.
E 30 Invalid product configuration.
E 35 Contact your authorised service agent.
E 100 Invalid PLU contents (try re-programming the PLU).
E 101 Transaction failed.
E 102 PLU write failed.
E 103 Tare failed.
E 151 Product configuration memory failed.
E 152 User does not have access to this item (in management mode)
Jan 29, 2017 | Home
Adding new PLU problem keep getting PLU Program Error
Those machines have a memory allocation section where you need to define the file sizes for products, etc. If your file size is smaller than the machine you are copying from, then it wont work. Try setting the memory allocation first.
Apr 04, 2014 | Samsung SAM4s ER-650 Cash Register
Hi, I bought a second- handed cash register UNIWELL LX5700. it was used for a fruit shop and come with a scale. but some PLU buttons only work by linking the scale. if I remove the scale and press these...
You need the software on the following link. Install that on a computer, hook the computer to the Uniwell regiister and everything can be modified. You can also upload all sales information from the register to the PC to do your accounting.
http://www.uniwell.com/unihtml/products/appsoft/tensai2000.php
Jun 18, 2011 | Office Equipment & Supplies
I need to get manual/user's guide for scale CAS LP 1000 (need to re-program the scale...) Thanks!
you can find the user's manual on the CAS corp. site..here's the link...just scroll down to the downloads section on the left and u can download there http://www.cas-usa.com/lp1000n.html
Oct 18, 2010 | Microwave Ovens
Casio TE-2400 PLU programming
Hi. You have been given the wrong instructions. That is why it is now all screwed up. Pricing is dead easy. You have condiments setup because you have set key features in prog 3 mode. It shouldn't be too hard to fix. We'll start with prices: Turn key to Program mode Type the price (no decimal point) Press a PLU (item button) to set the price to. Press SUBTOTAL To remove condiments, you need prog 3 mode. While key is on program, press 3 then SUBTOTAL. The display must change to "P3" Now press 0 (zero) then one of the PLUs that has condiments set. Press SUBTOTAL to finish. It may remove the tax status, so turn back to REG mode and test the PLU. If the tax has gone, then reprogram the tax setting for that PLU. Let me know if you get stuck. Mark
Jun 09, 2009 | Casio Parts Cash Register PC Desktop
How to merge (not found PLU) into scanning PLU file in casio te-4
Hi.
This is the only thing I haven't managed to do with them. I've tried many methods and consulted other techs, but it seems they are very separate memory areas. You will probably just have to program the product into the scanning PLU file as well.
If I find a way, I'll try to post it for you.
Mark
Feb 27, 2009 | Casio Parts Cash Register PC Desktop
TK 1550 casio
Hi.
I haven't worked with the 1550, but most Casios are the same.
Try this:
Turn key to program.
Press 0
Press the PLU that you want to set as open priced.
Press SUBTOTAL
That will set the price as 0 for that PLU. Now we set the feature for that PLU to allow manual pricing.
Leave key on program.
SUBTOATL
0
Press the PLU again
SUBTOTAL
Try that. If you had tax set to that PLU, you may need to set it again.
Mark
Feb 02, 2009 | Casio Parts Cash Register PC Desktop
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
CAS lp-1000n label printing scale Logo
47 people viewed this question
Top CAS Office Equipment & Supplies Experts
jasbo
jasbo
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
