Question about Husqvarna Zero Turn Mower Z5426
Husqvarna z5426 z turn mower when I engage the PTO it kills the engine! I have replaced all switches please help
How do I test the clutch to see if it is the clutch or the deck?
  • Husqvarna Master
  • 2,478 Answers
I would check spindle bearings and turning easy.
Posted on Mar 25, 2014
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 202 Answers
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Posted on Jul 19, 2009
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 21 Answers
SOURCE: husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Posted on Jul 27, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
LGTX 1050 Cub Cadet PTO will not engage blades on mower deck
If its an electric clutch it may not be getting power use a test wire from batter touch it to clutch and if you here it engage its ok sometimes the get corroded a bit and wont lick in but sounds like no power to clutch.
Apr 05, 2017 | Cub Cadet Garden
When i turn on the pto it blows the pto fuse
Make sure everything is able to move freely with the engine off. If the blades are not damaged or stuck, and the belt will rotate, it is either a bad electric clutch, the PTO switch or you have a wire(s) that is shorting to ground.
Jul 13, 2014 | Husqvarna Zero Turn Mower Z5426
When you inguage the ele pto it kill the engine whats the problem?
It could be a number of different things.
The starter switch has 2 different positions for safety. One will kill the engine while backing.
Have you tried engaging it with the switch in both positions? I would check that first.
If it doesn't kill the engine while in the safety bypass mode for backing, it would probably be a bad or stuck limit switch on the reverse linkage.
Jun 23, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
I have a husqvarna riding mower.. when i engage pto it kills the mower.. i direct wired the pto to the battery and it kicks on and off while mowing, mower runs fine when the pto is off please help
If you wired the pto directly to the battery and still kicks off and on, you have a bad pto clutch. They can be expensive but they are fairly easy to replace. Hope this helped.
Sep 07, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Ferris ztr model is4500z pto quit while mowing and wont re engage
check for power and ground going to the clutch and see if you have a bad clutch or bad wiring or switches
Jul 31, 2012 | Husqvarna Zero Turn Mower Z5426
Ariens ezr 1742 how can I test the electric clutch for the mower deck?
see if you have power and ground at the connector that feeds the clutch if you have power and ground to the last plug take the clutch off and check the wires as they go into the whindings
May 20, 2012 | Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Husqvarna Zero Turn Mower Z5426 Logo
126 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
