Question about Asko W6903W Front Load Stacked Washer / Dryer
Output drainage error
Several coins had jammed our motor filter. After emptying it we were still getting the error message. I ended up unplugging it for 24 hours, pulling the until out to check the hose in the back and then it worked for 2 washes. On the 3rd wash another coin got stuck in the pump filter. Now everytime I was a load it will not drain and I get the output drain error. I have tried shutting it off for several days but it will not reset. My husband insists it has nothing to do with the hose in the back. Any suggestions?
  • Asko Master
  • 5,323 Answers
YOU HAVE TO UNCLOG THE FILTER AND THE WATER PUMP ITSELF. CHECK TO MAKE SURE THE WATER PUMP PROPELLER IS NOT OBSTRUCTED? CAN U TURN THE PROPELLER BY HAND
Posted on Apr 03, 2015
3 Suggested Answers
dauphine
  • 207 Answers
SOURCE: Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Posted on Apr 24, 2008
  • 6277 Answers
SOURCE: getting f3 error message checked
Here is an extract of my guidance notes on checking filter and motor. Try the last paragraph in particular-
POWER OFF FIRST
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 11, 2011
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Getting f3 error message checked drain pump removed a coin last night re ran cycle empty still not draining ive had this message in the past and emptied drain pump and its always worked the pump is turning...
POWER OFF FIRST
John C
Jul 11, 2011 | Asko W6441 Front Load Washer
Hi there a message is showing up on my washing machine error 2 could you help me thanks
Haier 'Err 2' decodes as 'drainage error, water not emptied within 4 minutes'. I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults', such as slow emptying, are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside!
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 21, 2011 | Haier Washing Machines
The machine wont empty water gives a code of 03 I have cleaned the drain filter and check the drain hose still wont drain water unit is 1 1/2 years old
03 is drain error, as you know. The machine is sensing that the water isnt draining enough in 5 minutes...Unless there is an electronic problem the main reasons for the error code is because the drain hose is blocked, or the pump has something preventing it from turning, like a coin jammed in the impeller, or the pump motor itself needs to be replaced....These pump motors tend to get detritis in behind the impeller shaft seal and this often causes the pump to fail.....Good luck....Nomess
Jun 16, 2010 | LG WM2233H Front Load Stacked Washer /...
Hi , I have an elctrolux washing machine, and it stops half way through the cycle 'saying' E20. Does anyone know waht I have to do Thanks RN
E20 is difficulties in draining for washing. which can be drain tube kinked or blocked, drain filter clogged or dirty or the pump impeller behind filter is getting jammed by a coin or cotton or anything wrapped around it, remove filter and look at back of hole and see if impeller will turn use a long screwdriver to turn it, obviously with the power off
May 25, 2010 | Electrolux EW1000i Front Load Washer
Getting an OE error code on WM2016CW washer. Have checked the hose for bends and emptied the drain filter? Still getting error message?
OE error is because the machine is slow to empty..Check and see if the machine is draining slowly or not at all..Sometimes coins get caught in the impeller itself...The type of pumps used on LG machines can fail because of muck and detritus getting behind the impeller back plate..Dismantle pump. Mark pump and body to help with re-assembly. If impeller comes out of motor body, you'll have to feplace the pump motor..Universal pump motors are generally ok.. Gravity drain to empty machine.. Good luck....Nomess
May 19, 2010 | Washing Machines
Getting the OE error message on LG Tromm
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Not all water drains and spins out
sounds like your emptying pump is not working. main cause of this is something getting jammed in it, coins or a wire out of a bra eg.
if you are good at taking things apart tilt machine to one side, the drain pump is the tiny motor near the bottom of machine at the back of the filter cleaner flap. if you take the hoses off the pump you may be able to see what is jamming it. try spinning the blades on the pump, if they spin freely the pump needs replacing if they dont remove whatever is jamming it . hope this helps.
ja
Apr 10, 2009 | GE Washing Machines
I have a Frigidaire front end load washer with an error code 20
Jan 22, 2009 | Washing Machines
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
Asko W6903W Front Load Stacked Washer / Dryer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
