Question about QPS Q-See Video Recorder
Security dvr records movement will not record any more error
Alarm went off and it said error hdd video
I have a Pro 642 cameras. My camera stopped recording. In the menu alarm setting in the Exception part it says that the HDD is full. Can you help.
if you need the stuff on the hdd copy it and wipethe hdd on dvr what is the mb or tb on it you can add more this would help you ,how many cameras do you have aswell if you have say a dvr 4 and a 5mb this will only last days not weeks,if you have more you might need to up the hdd,just note the hdd a computer one will not work the same.
Jun 16, 2017 | The Video Cameras
Have an error message on screen sayng NO HDD???
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
Mar 30, 2015 | GW Security Professional 4 Channel 1t Hdd...
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Samsung ssc dvr -80
I dont think so, without a remote motion sensor..but you can set them up with the internal motion sensor and have it log the times that there is alarm activity or motion in your cameras... and you can just look at those portions of the recording and not the whole harddrive...good luck!!
Nov 17, 2008 | Samsung SSC DVR Digital Video Recorder...
Starts recording then stops
The manual says that it can be replaced with almost any standard IDE drive but mine has a Seagate 160GB drive in it so may want to stick with original equipment. Other than tha, any drive SHOULD work.
Jul 02, 2008 | Samsung 4 Channel Dvr
HDD Error
Since my last post, I have rectified the problem.....
1) I opened the unit to find a seagate HDD
2) I downloaded the Seatools in dos format and burned the image on to a cd rom
3)Taking out the HDD from my recorder,I hooked it up to another pc and ran the seatools disk @ bootup.
I tried for 2 hrs to repair the bloody thing ( 160 gb!) so i gave up and tried to erase the full HDD...which worked.
4) on my laptop i navigated to Pioneers site and found my recorder along with instructions and a zip file that contained 2 files.
5)After reading the destructions erm i mean instructions ;) I put the HDD back into the recorder and followed the instructions again..
Crossing my fingers i turned the recorder back on and to my amazement i was able to have more functionality..BUT... it says my HDD name error so I ran the disk again and wallah! all worked XDDDD
Here are the links
http://www.pioneer.co.uk/uk/content/support/support/update/DVR.html check if your model is there.
http://download.seagate.com/seatools/registration.nsf/desktop?openform Just add your email too download.
I hope you fix yours XD
May 05, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
QPS Q-See   Video Recorder Logo
Top QPS Televison & Video Experts
Electro Med Services...
Are you a QPS Televison and Video Expert? Answer questions, earn points and help others
