Question about HP ProBook 5310m (FM997UT) PC Notebook
Crackling static in sound
When audio is being played there is a crackling static sound coming from speakers. No matter whether I use internal speakers, headphones, or external speakers. Very annoying and frustrating.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
Reduce the volume of the microphone
Posted on Mar 25, 2014
4 Suggested Answers
  • 111 Answers
SOURCE: Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Posted on Apr 29, 2008
portland1970
  • 145 Answers
SOURCE: The internal speakers all of
sounds like the sound card board has a short. depending on the notebook, this may or not be replaceable. take it in and see if the board can be replaced
Posted on Jan 28, 2011
SOURCE: ac adaptor crackling thru external speakers
Allan, It sounds like you have what is called a ground loop. A ground loop can occur when two pieces of equipment are connected together through a home or buildings safety ground through the same power source. For instance, your PC is connected to a power source through the AC adapter or plug, and your external powered speakers are receiving power from the same power source. The surrounding cables as well as the AC adapter(s) can act like an antenna. This will cause a low hum or crackling that would be audible through the speakers or headphones.
You may want to try plugging all components into a power strip so they are all on the same circuit. You may also want to be sure that the AC adapter cables are not not laying or running across other electrical components plugged into a different socket.
If you get the same hum through your headphones check to see if the headphones were manufactured with shielded cabling. A shielded cable is made with a wire mesh around the outside that helps reduce electrical noise. Hope this helps a little. Thanks!
Posted on Sep 14, 2012
Why are my speakers crackling on my laptop?
Try removing and reinstalling the sound card drivers.
It might also be due to the volume being turned too high.
For external speakers - cheap or damaged cables will cause "static" in the speakers.
Dec 26, 2011 | Computers & Internet
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Speakers are making a crackling sound then cut out.
Sounds like an internal loose connection somewhere, possibly anywhere, a connector on a pcb, a dry solder, loose pin on an IC. Tough for an end user to solve this, would entail opening the unit and investigating. I checked the rear panel in the op manual and this model has no ribbon connectors else i'd have asked you to check them.
Mar 26, 2008 | Aiwa NSX-DS55 CD Shelf System
Stereo receiver crackling noise
open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Aug 13, 2017 | Audio Players & Recorders
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
PS3 hdmi Audio problem Crackling Sounds
Go to audio options, and manually DE-select Digital 5.1. That should fix it. It did for me.
Aug 28, 2007 | Sony Playstation 3 (PS3) Console
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
HP ProBook 5310m (FM997UT) PC Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
