Question about QPS Q-See Video Recorder
Security dvr stop recording
A alarm woke us up and said error for hdd video the dvr is 14 months old never had a problem before q-see series qc444 h.265
I have a Pro 642 cameras. My camera stopped recording. In the menu alarm setting in the Exception part it says that the HDD is full. Can you help.
if you need the stuff on the hdd copy it and wipethe hdd on dvr what is the mb or tb on it you can add more this would help you ,how many cameras do you have aswell if you have say a dvr 4 and a 5mb this will only last days not weeks,if you have more you might need to up the hdd,just note the hdd a computer one will not work the same.
Jun 16, 2017 | The Video Cameras
My dvr worked fine for several months and then all of sudden it stopped recording Could it be that the hard drive just stopped recording because of failure?
the HDD is a common component to fail in a DVR.
The DVR Itself should actually tell you the status of the storage device if you navigate the menu.
I could probably assist you remotely to find out if you like?
Apr 14, 2016 | Drive Televison & Video
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
Doesnt turn on i don now why?
Check your power supply to the DVR it's more than likely bad
Feb 26, 2014 | QPS Q-see QC444-411-5 Video Surveillance...
I have QC444 and I can't seem to get it working over the internet. I have Dlink 524 and opened up ports 83 and 37777. 80 used by another device. I am using Windows 7 and have opened up port 83 and 3777 in...
These units may have a firmware problem with Internet connectivity. After a week with their Tech Support They were unable to help me get it to send Emails and or FTP outbound. Although I was able to view the Video remotely.
Try setting TCP port to 37777, UDP Port to 37778 and HTP port to 83
Also, Be sure to enter at least one working DNS address.
Make sure the IP address of the DVR is in your Network. Make sure the gateway is set to your DLink's LAN IP Address.
Make sure you forward port 83 in your router to the IP address of your DVR. Check your router logs for any remaining issues.
Jan 09, 2011 | QPS Q-see QC444 Video Surveillance System...
Starts recording then stops
The manual says that it can be replaced with almost any standard IDE drive but mine has a Seagate 160GB drive in it so may want to stick with original equipment. Other than tha, any drive SHOULD work.
Jul 02, 2008 | Samsung 4 Channel Dvr
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
QPS Q-See   Video Recorder Logo
50 people viewed this question
Top QPS Televison & Video Experts
Electro Med Services...
Are you a QPS Televison and Video Expert? Answer questions, earn points and help others
