Question about Singer 14CG754 - ProFinish Serger
Serger threading problems
The threads, especially the one the left of my serger is very tight when I try to pull it through. I believe it has something to do with the tension discs. How do I make it come through smoothly?
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
Oct 02, 2016 | Singer 9960 - 9960 Quantum Stylist
Confidence Quilter 7469Q how do I load the bobbin?
Are you trying to wind the bobbin or just dropping it into the bobbin case and bring up the thread?
To wind the bobbin, place the spool on the pin and secure it with the spool pin cap. Pull the thread and pull it through the thread guides. The first guide is accessed by going around it and then pulling the thread under it. Go under the adjacent guide and then wrap the thread counter-clockwise (when facing the front of the machine) under the next guide to bring the thread back to the bobbin winder. Hold the bobbin with the hole up and pull the thread through that hole. Push the bobbin winder shaft to the far left and place the bobbin on the winder pin. Push the bobbin and winder shaft to the right until it clicks. Hold the thread and start the sewing machine. It will automatically stop when the bobbin is full. Move the bobbin winder shaft and bobbin to the left and take the bobbin off. Then cut the thread to separate the bobbin from the spool thread.
To put the bobbin into the bobbin case and bring up the thread:
Make sure that the needle is in the highest position (use the handwheel). Then open the bobbin cover by pressing the release lever to the right and then lifting up the cover. Hold the bobbin with the hole up so that the bobbin turns counter-clockwise when you pull the thread. Drop the bobbin into the bobbin case. Pull the thread into the slot just to the left of the bottom center (6 o'clock on a 12-hour analog clock), of the bobbin case. Place a finger on top of the bobbin and pull the thread to the left until it stops at the slot between the 7-8 o'clock position. Now pull the thread along the groove in the needle plate to the thread cutter. Replace the clear bobbin cover. The thread should be pulled up by the needle thread without any additional effort. (If it isn't, there may be a problem with the bobbin case or race.)
Singer has the manual for the 7469Q on their site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/549_7469_efs.pdf . Winding the bobbin is on page 16; threading the bobbin at the bobbin case is on page 18. These pages have good pictures to go with the descriptions.
I hope this helps.
Sep 12, 2016 | Singer 7469Q - Confidence Quilter Machine
Only had machine for a couple weeks and the the automatic thread cutter button doesn't cut the thread. still have to pull the thread up out of the bottom
There may be thread stuck in the cutter, or the tensions are too low to hold the thread fetcher to pull it across the knife. I would suggest returning it to your dealer for some help.
Mar 04, 2015 | Singer 9960 - 9960 Quantum Stylist
Singer 3321 Talent Sewing Machine jammed after one turn forwards or backwards, even when thread and needle removed it won't work
This sounds more like the motor is bound up. The other solutions are, check for thread wrapped around moving parts, any belts that may have become displaced.
Mar 01, 2014 | Singer 3321 Talent Sewing Machine
Singer 9960 automatic thread cutter not working
I'm looking for a solution to why the thread cutter isn't working. It just pulls the thread into a knot and jams the bobbin case. I was hoping for an answer here but the answer had nothing to do with the question!
Sep 20, 2013 | Singer 9960 - 9960 Quantum Stylist
I tried to bring the inferior thread up after put in the bobbin but the needle do not pick up and stopping me for sewing
Is the bobbin put in right? Make sure the thread is coming off the bobbin in a counter-clockwise direction. Also make sure you're leaving enough thread coming off the bobbin for the top thread to grab hold of to pull up.
Feb 18, 2013 | Singer 8763 Curvy Electronic Sewing...
I need a Singer Profinish "Thread Tree" replaced. Where can i order one?
Here is a link to a parts supplier.
http://www.sewingpartsonline.com/singer-14CG754-serger-machine-parts.aspx
The part you describe is:
4 Thread Holder, Universal #412519
$25 plus shipping
Feb 03, 2013 | Singer 14CG754 - ProFinish Serger
Sewing machine keeps skipping stitches
Generally, it means that the bobbin is too tight in the cavity.
1. Remove the bobbin
2. Try a drop of oil in the bobbin cavity in the machine, using a Q-TIP
3. After applying the oil, use a clean Q-TIP to remove excess oil in the cavity (may need more than one clean Q-TIP).
4. Replace bobbin.
(I'm sure you already tried differenty thread)
Hope this helps!
Sep 01, 2009 | Kenmore Irons
Singer 14CG754 - ProFinish Serger Logo
48 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
