Question about Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2009 2010 2011
Trunk door latch power lock. How to stop the noise from the trunk door
    Top Expert:
  • Mercedes-Benz Master
  • 11,573 Answers
It sounds like you have a loose fitting trunk lid, in which case you will have to loosen trunk latch and adjust it so it can seal tighter on weather stripping
Posted on Apr 08, 2014
My remote start stopped locking my trunk when I lock my doors. So I have to lock it with the key. How can I fix it back so the remote locks the trunk as well?
Hi Tamika, Im AL the owner of Big As Auto Repair.
Tamika, I'm not sure what vehicle you have but, there are only 2 styles of trunk lock actuators. (1) Is built into the latch itself and if you have this style the latch will need to be replace. (2) The other style will have a rod running from the latch over to a lock actuator, with this style you'll need to replace the lock actuator. NOTE: With either style, you'll first need to make sure you have power and ground to it, and if you have both power and ground then it needs to be replaced. If you do not find either power are ground you'll need to find out why and repair that problem. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Dec 28, 2015 | Cars & Trucks
Door lock icon on my car dash will not stop flashing
Try from another door or trunk locking then unlocking. If it still does not go out then take door panel off and inspect door latch and harness
Apr 01, 2014 | Locks & Locksmithing
Tailgate door wont latch
IT sounds like you closed the Trunk/ Liftgate with the Latch partway closed. Lube the Latch and hopefully it is not bent. If it is not latching, you can try and ensure it is aligned propery (use a piece of Tape and see where it is hitting the STRIKER...
If not, you are going to be replacing the Latching Mechanism.
Apr 06, 2013 | 2009 Honda CR-V
Trunk will not stay locked
I would suspect a faulty latch. You may have to have it removed and examined.
Dec 07, 2012 | 2009 Ford Fusion
After jump starting trunk latch,sunroof,door locks and map lights won't work
when jump starting volvos turn the lights on this will stop the power surge from blowing fuses or relays that have stopped all your bits from working
Jul 31, 2012 | 2001 Volvo S60
My trunk latch won't open and I want to know how to access my trunk from the back seat.
Your trunk latch is coupled with the rear door lock, push the door lock down then lift it up, do not use the auto lock/unlock. It should release the trunk lock, I had the same problem.
Feb 01, 2011 | 1992 Volvo 940
1996 lincoln continental door latch does not lock/unlock door from inside or outide...door stays open basically...door latch has no response, unlock/lock switch works
I have the same problem.(Door will not stay closed) The door latch itself seems worn to the point where the linkage from both the actuator or door handle causes the latch to get stuck. I can free it with a screw driver applied where linkage connects to the latch, but it will stick again. Dealer wants over 300 with actuator. I am looking in junk yard for part. Remove door panel, somehow disconnect linkage from latch. It makes more sense to remove 3 hex or star screws 1st (27mm) so latch will be more accessible. My problem is the door latch, not anything else. Good luck
Jan 24, 2011 | 1996 Lincoln Continental
Power door lock, driver side only, does not work in my '95 Sable
if you here a noise that should mean the little motor (door lock actuator) thar works the door lock is getting power to it and it should be ok. sounds like when you changed the inside latch you must have disturbrd/disconnected the linkage or the clip that connects the lock actuator to the latch assembly(the female V-SHAPED mechanism that engages the POST/STRIKER (male part) its a little hard to name these parts so i am describing them to you. look insidethe door and see if you see any threaded RODS OR LINKAGES that are not connected at both ends.the noise youre hearing is most likely the door lock actuator "spinning"up and down but its unable to lock or unlock the door latch mechanism.
Sep 01, 2009 | 1994 Mercury Sable
PLEASE HELP. Dead battery on 1989 BMW 3series with power locks.
Why dont you call loc smith to unloc the doors
You could take flat screw driver to try push the latch side ways where it latches
Jul 29, 2009 | 2001 Porsche 911 Carrera
Latch of trunk won't open.. lots of clicking noise.
Had the same exact trouble. Changed the relay #36. Check the owners manual pages that show where all of the fuses/relays are. The fuse box for this relay is in the trunk area so I had to crawl in cuz the trunk wouldn't open. Good uck...hope this helps
Jul 22, 2009 | 2004 Chevrolet Malibu Maxx
Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2009 2010 2011 Logo
81 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
