Question about Cuisinart DLC-10S Pro Classic Food Processor
MACHINE WON'T TURN ON AFTER BEING USED
THERE IS A DEFAULT BUT I FORGOT WHERE IT IS
    New Friend:
I am guessing that something is not seated properly. Make sure the bowl clicks when turned...drops the pin in. Make sure the top is ("clicked in") locked. If you poured something out of the bowl and went to re-use it, make sure the blade is seated properly; make sure there is no food caught under the blade hindering the blade to be seated. Everything must be locked in correctly to operate safely.
Posted on Mar 25, 2014
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
Magimix is the best name in foods processors. They are very reliable with a direct drive motor. As I am sure you know that have a safety interlock, and this may be what is giving you the problem. The bowl has to be locked in place with the handle over the interlock button in the base. This is with the handle dead centre of the front of the machine. It won't work if you decide the handle would be better off at the side of the machine. Then the lid has to be locked in place with the lug in the slot in the top of the bowl. Only then will the machine operate.
If all that checks out, then you will need a service centre.
magimix service agent Google Search
The instruction manual is accessed from here
http://www.magimix.com/usa/page/Instructions-for-use
Dec 10, 2017 | Magimix Food Processors
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Nov 24, 2017 | KitchenAid Food Processors
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
I can't get the food bowl off the processing unit. i have removed the cover as the manual says. I have left the blade in as the manual says. The picture looks as thought you should just lift it...
On page 8 of the manual that I will give you the link to: leave the cover in place on the container. Use the cover to help remove the container. Rotate the cover clockwise 180 degrees until the two tabs on the cover meet the two container tabs. Continue to turn the cover, but do not press down as you turn, using your thumb against the tabs until the container is released. Empty the remaining food from the container.
http://kitchen.manualsonline.com/mdownloads/c44fa16e-225f-49e2-84e5-348ee18b9c1b.pdf
Jul 15, 2010 | Sunbeam 4817 Oskar Food Processor
Need an instruction manual for moulinex la machine model 390
I have an order of parts coming that I won on eBay, which I wanted for the DoughWorks, plus to replace my lid for the Vegetable Chef, as mine has a broken strap. I never had a manual, as I bought my processor second-hand over 25 years ago. I just figured out on my own how to use it. The box of parts I am getting has a manual, and I will be happy to scan it. Please send an email to clay_pots_47@msn.com and put La Machine Manual in the subject line.
Oct 15, 2009 | Food Processors
Operating switch
You could try a shot of contact cleaner inside the guts of the switch. Perhaps over time some sticky residue has built up causing the switch to become frozen. Unplug the unit, spray inside the guts of the switch, work the switch back and forth. repeat unit the switch loosens up. BE SURE to use a contact cleaner that won"t damage plastics, will say on label!
Jan 09, 2009 | Food Processors
I need a part
Are you looking for the blade assembly for the chopping bowl? It has the blade and removal tool. I have an order of parts coming that I won on eBay, which I wanted for the DoughWorks, plus to replace my lid for the Vegetable Chef, as mine has a broken strap. There are duplicates of parts I won't need in it. Please send an email to clay_pots_47@msn.com and put La Machine Parts in the subject line and describe what you need. I can't help those of you asking about La Machine II, entirely different machine. I only have parts to fit the original Moulinex 500 series machines.
Nov 27, 2008 | Moulinex DG6 Food Processor
Gift came with no manual
http://www.euro-pro.com/europro/default.aspx
You can order the parts and possibly the manual for this on this website. There is a customer service contact number there also.
Jun 10, 2008 | Bravetti Platinum Pro Quad-Blade Food...
Need Manual
May 29, 2008 | Moulinex DG6 Food Processor
Cuisinart DLC-10S Pro Classic Food Processor Logo
179 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
