Question about SK Hand Tool Altenator / Power Steer / Air Pump Pulley Puller
2000 chrysler intrepid no power steering
Power steering just stopped working its not leaking and is full. motor is a 3.2 is there a electrical plug that's on this pump ?
    New Friend:
More than likely the pump is bad.
Posted on Mar 25, 2014
Okay so if i have fixed my power steering pump have had the rack and minion looked at what else would make my power steering not work on a dodge intrepid
Some Chryslers had a variable assist PS solenoid on the rack and pinion. It lowers PS fluid pressure during higher speed driving-highway driving, but allows full PS pressure during low speed driving. It would be located on the top of the rack, towards the drivers side, and would have an electrical connection to it. If you have this feature (variable assist power steering), have a shop diagnose it. I don't know the testing procedure.
The power steering belt is tight and not slipping?
Jul 02, 2014 | Dodge Intrepid Cars & Trucks
Power steering not working
Hi there, check to see if your power steer reservoir is full, if so then your power steer pump has failed, they usually make a noise when low on fluid, that would be the first place I would check, then check for and fluid leak from the reservoir , hope this helps
Mar 08, 2014 | 2000 Chrysler Concorde
2006 Peugeot 307 power steering
If it's the electrical motor type of pump, you must connect to a full scale scanner like Lexia 3 to get it reset.
Mar 01, 2014 | 2006 Peugeot 307 1.6
Power steering pressure hose leak
Power steering hose leak causes, likely to have a defective power steering pump. You can get Chrysler power steering pump at http://www.steeringpumps.com/chrysler-steering-pump/ Hope this solves your problem.
Jul 18, 2011 | 2000 Chrysler Grand Voyager
Power steering rack leak 1997 chrysler intrepid
If the rack has a leak from inside the bellows,
not just a hose going to it
The rack has to be replaced
The fluid gets flushed every 30,000
miles, when you do your trans at 30,000
miles & never over 3 years
Jun 16, 2011 | 1997 Dodge Intrepid
I have a 2000 Chrysler cirrus and have had a problem with the engine smoking underneath where u put in the steering fluid (located underneath the lip where the passenger wiper is when hood is up) I've...
its hard to diagnose this with out looking at the motor and finding the leak... sounds like you have some power steering fluid leaking onto your motor. check the power steering lines for leaks. fix the leak..and clean the motor.. if you cannot find a leak.. try power washing the motor... do this by turning on the car and degreasing the motor where you see oil stay away from the spark plugs and distributor and battery terminals while washing the motor.. Good luck..
Mar 17, 2011 | 2000 Chrysler Cirrus
DODGE INTREPID
They are pretty reliable. Transmissions sometimes have problems and battery changing, etc isnt easy. I have had 2 concordes and 2 intrepids, as well as a van from chrysler and for the most part they are fine except the transmissions. have had to change the transmission in 2 of the cars and the van (which takes a different one). Engines are good if taken care of. Rick
Jul 04, 2009 | 2000 Dodge Intrepid
2000 fiat seicento, problem with powersteering losing power also the speedo stops working at same time. this is a intermittent fault. power steering is electrical and is situated at top of steering column...
Best suggestion I can make is make sure the power steering fluid is in the full range (either hot if you've been driving more than 20 miles, or cold if the engine has been off). Always check the fluid with the engine off. If the fluid smells burnt, have a mechanic check the power steering pump for damage. Also check around the area for any leaks.
Another thing to look at is the wiring and fuses for the power steering and speedometer. Try to follow them to see if there's any bare, rubbing, broken, or loose wires. Electrical systems are a pain to diagnose specifically, and it may be better to have a mechanic look at it for you but fuses are easy to check.
Mar 01, 2009 | Fiat 124 Cars & Trucks
Power steering leak
Depends on the part to be replaced. The pump is pretty straightforward with the correct tools and costs about $60 to $100 if you do it yourself (I own an Intrepid, similar to the LHS and I work on it a lot) . If it's a metal hose, this is going to be about $30 to $50 or more and will need a flare nut wrench, along with other hand tools. If this is attached to the steering rack, you may have to move other parts out of the way. This is not a hard job either, but could be time consuming and be careful not to cross thread the fittings.
Jun 21, 2008 | 2000 Chrysler LHS
SK Hand Tool  Altenator / Power Steer / Air Pump Pulley Puller Logo
49 people viewed this question
Top SK Plumbing Experts
Gil Shultz
Dan Apthorp
Jim Goldsmith
Jim Goldsmith
Are you a SK Plumbing Expert? Answer questions, earn points and help others
