Question about Grinders
Bench grinder switch
I'm trying to find a power switch for an MD3215 bench grinder, 250v/120v, 3/4HP, 3420RPM... any suggestions?
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
  • 384 Answers
SOURCE: NEED ON/OFF SWITCH FOR BUFFALO BENCH GRINDER
You can get a replacement toggle switch at any hardware store look in the electrical department.
Posted on Jun 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Posted on Dec 28, 2009
Testimonial: "Great solution. Yhank you. - b"
  • 172 Answers
SOURCE: Need part numbers to replace eyeshields on Dayton bench grinder
Your grinder is listed on page 3085 of the Grainger catalogue. The part number for the eyeshield is 00281.00 and the number for the lower eyeshield bracket is 00280.00. The right hand upper eyeshield bracket is number 25188.00 and the upper left hand bracket number is 25177.00. All of this can be ordered through Grainger at 1-800-323-0620. Marvin T.
Posted on Jan 13, 2010
Testimonial: "This was very helpful. I have ordered parts from Grainger. Thank You."
rowdy45176
  • 2176 Answers
SOURCE: I am looking for a Dayton Bench Grinder Manual
I would try and call Grainger parts to see if they have one. I know they deal with and sell Dayton equiptment. If no luck let me know and I will try and find another source.
Posted on Mar 25, 2010
When I turn it on, nothing happened.
motor either is shot or not getting electric . if motor runs then the belt is gone
Mar 08, 2015 | Delta 14-651 - Hollow Chisel Bench...
On/off switch buffalo bench grinder
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Nov 20, 2013 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a single speed Delta 8" bench grinder. How
as for slowing it down, no problem. Hook it to a cord with a dimmer switch connected to it. Make sure your running with the same power rating though. As for a dripper, no ideas just yet.
Mar 10, 2011 | Delta ShopMaster 8in Grinder with Light...
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
17202 8'' bench grinder 3yrs old hasent run 1 hr needs on off switch wilton stated after 6mos of waiting for soposed back order that co that maid these for wilton is out of business they said try lowe;s...
go to your local marina and buy a simple on off switch or take the wires off the switch on your grinder and hook them up to a extension cord and put an inline light switch on the cord.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
What are the power source requirements for a DeWalt #756 Grinder?
My experience of bench grinders suggest 15 amp will be enough, certainly at 240 volts . If you are 110 then I think it will still be enough but you dont make clear what the wattage of your machine is.
Jun 06, 2010 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Bench Grinder blown fuse
try the fuse first then try the red reset button under the base.
Mar 05, 2010 | Clarke Power Products Cast Iron Bench...
I need a replacement switch for a craftsman 1/2 HP bench grinder model#397.19441. I have no owners manual or parts list. This grinder is several years old.
Dec 28, 2009 | Craftsman Grinders
Given a bench grinder which did not work. How to test/fix?
I cleaned all the wiring connectors etc and used a 4-way extension cord with an i/o switch and thermal/arc breaker surge protector thingy. I had a piece of thick cable with a molded three prong plug which I had removed from a dead paper shredder (I think??) and connected the ground to the case (previously not connected) the black to the black and white to the white. I taped the connections and plugged the test cable into the extension thingy with its switch off and plugged it into the wall outlet. Then, with the grinder switch on, I gingerly switched on the extension thingy and the grinder (sans all moving parts) ie just the motor case and spindle (held securely in the B&D workmate) and viola(!) it worked fine and built up to very fast. I switched off the grinder switch and the motor slowed, taking an age to come to rest.
Then, I fitted a grinding wheel on the left hand thread end, tightened everything and retested, using the grinder switch to start it and it spun really fast.
Soooo, I guess the secure ground is an essential feature of a capacitor induction motor. I checked some old furnace motors that were "maturing" in the basement and they had no capacitor but only 2 wires...
I am now trying to remember which parts came off last and put it all back together. I plan to test it each time I put a part back...just in case. I hate it when you fix something on the bench and when rebuilt, it won't work...don't ask about the electric starter on the snowblower..not a happy puppy!
Please, pretty please and then some, do tell me if my "fix" is wrong and I could risk all kinds of nastiness.
Thanks,
Jenni.
Jan 24, 2009 | Grinders
Grinders Logo
127 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
