Question about Arcade Raw Thrills Big Buck Hunter Pro Video
Brigth good evening I have a problem the monitor shows a low brightness and the guns does not work but if I enter to menu of the chassis it look in the right color and brightness but begin the game still no clear can you help me please tanks I m Ricardo l from san Luis in Mexico
My viewsonic VP930b-3 LCD monitor went too dark even I put the maximun brigthness, then I tried to use " Memory Recall" function in set up menu. The monitor will show up in good collor ( bright - shape) in...
Based on the specs it looks like this monitor is a CFL type and not a LED type. That means it uses a inverter to power the CFL tubes in the LCD. Usually these go bad after awhile.. usually the capacitors on the board run dry or go bad and need to be replaced. If your not good with soldering you might be able to find a board to replace it with.. more then likely given the monitor size "small" the inverter board is usually built-in on to the power supply board or mainboard and will need to be replaced together but some times comes seperate as it's own board. You might just consider replacing the monitor, LED monitors are pretty cheap now a days and more energy efficient.. and should last longer then most CFL type monitors because they don't use as much current and don't produce as much heat and LEDs tend to last longer with out the yellowing effect of CFLs. However it really comes down to build quality & component quality. While the most likely cause is a bad inverter other things can cause this too..like a bad mainboard sending voltage signal lower then normal to the inverter board.
Nov 04, 2013 | ViewSonic VX2235wm LCD Monitor
Too much brigthness
Adjust the Brightness in Power settings or Press the little blue "Fn" button next to the left "Ctrl" button. Then while still holding down the blue "Fn" button, tap the left and right arrow keys accordingly to increase/decrease the brightness.
Nov 03, 2012 | Acer Aspire One PC Notebook
I can't able to adjust contrast or brigthness from my acer led monitor.plz help
Press the buttons on the front of the monitor until you find the menu ... look for brightness adjustment there.
Mar 04, 2011 | Acer 19" LCD Monitor
E70fSB main menu keeps on prompting
your monitor low voltage regulator LM7805 inside needs replacement..electrical noise is entering the microcontroller of your monitor..bring the unit to the nearest monitor repair center..
May 10, 2010 | ViewSonic 17" CRT Monitor
Hello how to adjust brightness on an ACER 19" LCD monitor? thank you Kurt
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
Apr 01, 2009 | Acer X193W LCD Monitor
Monitor
hi if your pixel is permanently brigthing you can try to press gently on the screen on the bright dot to expanse the liquid, sometimes the pixel freeze on lcd monitor.
hope this helps
May 22, 2008 | Computers & Internet
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Brigthness Can't see picture
click on menu and try adjust the volume. just trial and error on that part. follow the standard procedure for all menu... 1st brightness, 2 contrast...etc
Mar 16, 2008 | Televison & Video
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Retrace line on monitor
To prevent serious damage and extend the life of your monitor you need to adjust the main brigthness control of it. it is of the LOPT/Flyback transformer inside of your monitor!
check also for cold SOLDER joints on the main pcb and also on the crt neck Board.
Nov 16, 2007 | Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT...
Arcade Raw Thrills Big Buck Hunter Pro Video Logo
16 people viewed this question
Top Arcade Toys Experts
jasbo
jasbo
ray gallant
kenneth j barron
kenneth j barron
Are you an Arcade Toy Expert? Answer questions, earn points and help others
