I have a Dell E196FPB 19" LCD Monitor and a Dell AS501 soundbar and the soundbar connects perfectly, but I can't find the 12v plug-in for the soundbar on the monitor. I can't seem to find whether or not, specifically, the monitor has a plug-in or not but it connects right and I've seen pictures of monitors with them and people selling them together on E-Bay.
SOURCE: Dell E196FP lcd screen broke
Generally the LCD screens are covered under 3 yr warranty. If you have purchased it as a seprate product from Dell. Otherwise it would have same warrnaty as your computer system.
You would end up sepnding more money in repairing the LCD , getting a new one would be a better proposition
Thanks
mandeep
SOURCE: Speaker Bar connection
There are 2 placces on the underside of the monitor for the speakerbar to slide into. For that model You will probably need the external power supply.
SOURCE: my dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
SOURCE: Describe your Dell E173FP 17
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
SOURCE: Dell 19" LCD E196FPf monitor
Yes, Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://s807.photobucket.com/albums/yy352/budm/Dell%20%20E196FP%20Rev%20A03/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
