Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
The simple tech turns on, my computer found it once but would not let me open it.
I can't find the external drive on my computer
  • etrc_new Apr 25, 2014
    Hi travlr99_1, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? And what happened on subsequent times you connected it ? Are there any messages, error or other ? What's your operating system ? Do you have data on the disk, and can you afford to lose it ? (I should stress that this point that you should keep regular back-ups of your files)
    25.April.2014
SOURCE: Simple drive external backup
You need to use the Storage Sync program provided with the drive. You can get the latest version at the Simple Tech website
Posted on Sep 26, 2007
eastpole
  • 22 Answers
SOURCE: does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Posted on Sep 04, 2008
Ynnoj
  • 4 Answers
SOURCE: Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Posted on Feb 25, 2009
bob_computer
  • 3153 Answers
SOURCE: Simple Tech 250 GB external hard drive won't work
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 23, 2009
  • 191 Answers
SOURCE: I need driver software for my external hard drive
I checked for one on SimpleTech's (Hitachi) website. The only show a driver for Windows 98. This leads me to think you don't need any drivers. USB is hot pluggable. Just plug the drive in. Windows XP/Vista/NT will plug a driver in for you (a USB driver). Drive will be given an access letter. You can then access like any other drive from Windows Explorer. Sometimes, USB drives have additional software on them (known as firmware) that you can then run directly from the drive. The firmware is not require to use the drive, but may offer features like backup software.
Posted on Oct 11, 2009
I have a Simple Tech (simple Drive) 320GB external hard drive.the light comes on But my computer won`t recognize it. The light comes on but that`s it.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Jun 12, 2010 | SimpleTech 320GB SimpleDrive External by...
HOW DO I COPY DATA FROM MY COMPUTER TO MY SIMPLETECH DRIVE?
Attach the simple tech using the USB cable, wait for the computer to read the new hardware and install the driver, the new drive will appear in the "My Computer" folder which shows all the attached hardware. The computer will issue the new external drive a drive letter, that identifies it to the computer. Double click on this external drive to open it. The right click on any file you want to copy over to the new drive and click on copy, then go over to the external drive folder and right click and hit paste.
Jan 13, 2010 | Computers & Internet
Simple Tech external memory 1.0 tb not registering all the sudden
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths".
Give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 21, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
My Hp Slimline won't recognize my new Simple Tech Mini-Drive
I`m David ncc student , question is about the characteristics of various network computers (NCs) currently on market? please help me
Mar 08, 2009 | HP S3120N Pavilion Slimline Desktop...
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Simple Tech external hard drive
if you are running windows, then check the following:
go to control panel -> administrative tools -> computer management -> storage -> disk management.
you probably have a drive (located on the bottom right) that is listed with no drive letter, just assign it a drive letter and see if it comes back, if not, the drive is probably not initializing and you might have to either format it or replace it.
Jun 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Sep 20, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
