Question about Dell Computers & Internet
Black material on back of N5040 CPU heatsink?
Hi, i disassembled an N5040 laptop, for LCD replacement. I did an extensive deep cleansing of all the parts. when i removed the CPU heat-sink, i noticed some kind of black material around the edges of the thermal compound, resembling a type of sticker. when i cleaned the heat-sink with alcohol, the black material was also removed. what was that black material? is it necessary to replace it? (or i can ignore it while reassembling) if so, how can i replace it? and where would i look for it? P.S just for clearence, im not talking about the thermal compund.. i know i have to replace it. i found a picture of it on a replacement heatsink, on ebay: http://www.ebay.com/itm/Dell-Inspiron-I15N-N5040-Series-Laptop-CPU-Fan-Heatsink-Y2JM0-0Y2JM0-/180950793458?pt=LH_DefaultDomain_0&hash=item2a2181fcf2
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Hi, these are thermal plastic sticker to make the thermal paste in tack and in place. as long as you know how to apply the thermal compound in the right way there's no need to replace it.
thanks
Posted on Mar 31, 2014
Black rectangular material on N5040 heatsink?
The black material can be a insulation sticker though u don't have to worry a lot about it .... Ignore it
Mar 25, 2014 | Dell Computers & Internet
N5040 black screen
remove the battery and the AC charger and press the power button
then connect the AC charger and press the power button
Feb 09, 2013 | Dell Inspiron Computers & Internet
Cpu are heated very much plz help
Hi Friend, In this case I would recommend you to please clean off the air vents of your system that is one of the cause of CPU getting heated up and other thing I would recommend you to please upgrade the BIOS of the system.
Dec 08, 2010 | Intel D946GZIS Motherboard
Can't boot up my acer 290 notebook as the screen is
Hi,try making sure your heatsink is properly seated on your cpu chip with some cpu compound between them......I had a laptop that did the same & when i checked the cpu heatsink & fan i noticed the screws holding down the heatsink onto the chipset had come away so i applied some compound to the centre of yhe chip reseated the heatsink with longer screws & i also gave the heatsink & fan a good clean,put it all back together & it worked fine...goodluck
Jun 06, 2009 | Acer TravelMate 290 Notebook
Overheating although cooling fan & heatsink are ok
u r saying that the laptop is overheating. I think it is from cpu overheating right. just to make sure that it is cpu overheating, just go to the following link and download the software around 1mb which displays each and every component heating levels.
from that you can find out the exact component.
http://www.cpuid.com/software.php
if cpu is heating then just replace the thermal interface material and the problem will be gone.
if the cpu thermal interface material is too old then this type of problems arises
Apr 19, 2009 | Computers & Internet
Laptop shutting down by itself
Your CPU chip may be overheating and/or your screen backlight may cut out as well. This is common of the VAIO PCG-F series Laptops.
Disconnect the power from your laptop and remove the battery.
To repair this issue, you must feel comfortable to solder SMD components and have such solder equipment as well as watch makers screw driver tool set. You will also need some copper shimming material, about 1-2mm thick and thermal grease/paste.
Eye piece Magnifier is useful as well.
Over time, the thermal contact material SONY used shrinks. It shrinks between the CPU chip and the Heat sink, effectively impeding the cooling efficiency of the fan/heat sink.
Clear indication for that is the Fan runs at full speed all the time.
Carefully open your laptop, (be sure you are ESD safe) and carefully remove the keyboard to get access to the CPU/heatsink.
Remove the heatsink and notice the white sponge material between the CPU and Heatsink is likely no longer making physical contact.
Fabricate copper shim to desired size and install the copper shims instead of the sponge, make use of the thermal grease on both sides.
Reinstall the heatsink.
To fix the LCD backlitght, carefully remove the 4 rubber thingys in the corners of the screen, and open the screen.
On the lower side there is a slim Board wrapped in some plastics.
Carefully remove this board, remove the plastic wrap and look at the soldering spots on the Ferrite Transformer. They may be cracked and need resoldering. Resolder as needed and reinstall the board.
If you do not feel comfortable to do this, then find someone who is.
Perferly a technician with experience in such fields.
Good luck
Dec 06, 2008 | Computers & Internet
Laptop Heating up
this is a general problem, with most laptops not just Acer.
the more modern-faster and more memory installed, all contribute to these factors. battery power is standard for lasting anywhere between 45 minutes to 2 hours. 2 main causes of overheating, are that the fan exhaust outlet may be blocked or restricting warm air extraction from the cpu. secondly the heatsink material ( Thermal-Patch Or Paste ) between cpu and heatsink, is insufficient. there are other reasons but these are the 2 most common. if the laptop is warranted, i,d suggest returning it, for repair/replacement. if it isn,t then locate the cpu fan, and clean out any dust build up, usually between the fan and outer casing.
hope this helps you.
Mike @ Compurepair.
Aug 19, 2008 | Acer Ferrari 4002WLMi Notebook
No power up on Satellite M35X-s111
Heres the fix:
This requires access to the cpu and heatsink, remove the keyboard and palmrest to access the motherboard, I think you have to remove the screen too. Remove the heatsink and cpu. Reseat the cpu, heres the kicker, press firmly on the center of the cpu while turning the locking screw. Pressing the cpu hard, allows the locking mechinism to get a good bite. Turn the locking screw hard into the end of the turn. Hook up the heatsink and set it back on top of the cpu. Press down on the heatsink over the cpu, fairly strong pressure.
Now test the motherboard, use just cpu, heatsink, memory, power button board and cable and external monitor, you can use your screen instead by just hooking up the cable to motherboard, leave the screen laying flat on the table. Now push the power button with one hand and the other is still applying pressure to the heatsink, no you dont need to screw it down yet. Keep reseating the cpu with varying degrees of pressure if you dont get it go the first time.
The trick will be to get it all assembled with the same results.
There seems to be a problem with the cpu seating correctly, it must come loose and the laptops exhibit the symtoms of no video. It might even be neccessary to insert a wafer thin piece of copper or something in between the cpu and heatsink if the heatsink doesnt apply enough pressure to cpu to keep it seated deep enough to run the computer.
Jun 29, 2008 | Toshiba Satellite M35X-S111 Notebook
Dell i6000 - Pink Screen
you are losing video from the motherboard..could be the video chip, yet this sort of thing can happen with laptops.
Feb 18, 2008 | Dell INSPIRON 6000 CENTRINO...
Overheating
yes its probably the fan but it could also be the screen brightness. replacing the fan and turning down the brightness will cool the laptop. but i agree try a new fan first.
Dec 26, 2006 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
