Question about Refrigerators
Kitchenaid KSRL25FRBL00 all lights are staying on but the refrigeration keeps shutting off
We have a KitchenAid model KSRL25FRBL00, we opened the fridge the other day and all of the lights were on but the fridge and freezer were not cold. We vacuumed out the bottom in the front and dusted off the back. After we unplugged the refrigerator and plugged it back in, it started working. The next day the same thing happened. Can this be fixed or do I have to get another refrigerator?
    New Friend:
    Problem Solver:
  • 6 Answers
Make sure that you removed all the dust - check thoroughly with a flashlight to make sure. It sounds as the unit is overheating - not drawing enough air through the condenser. Unplug the unit and clean it thoroughly and give it another shot - make sure enough air can be drown in. If this does not work for you might want to call a repair company.
Posted on Mar 25, 2014
5 Suggested Answers
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
  • 5 Answers
SOURCE: My KitchenAid KBRS22K bottom mount refrigerator is
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
Posted on May 20, 2009
SOURCE: Kitchenaid fridge #KSCS25INSS hot door frame
how to change the waterhose my Kitchenaid fridge #KSCS25INSS
Posted on Sep 12, 2009
imufo2
  • 3773 Answers
SOURCE: the freezer fan just shut
Some freezer fans won't work unless the temp in the freezer is low enough. About 10 degrees or so. Try these next.to get it colder
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 02, 2011
Kitchenaid icemaker will not shut off when bin is full of ice. Model: KUIS18NNXSo
Is there a wire/bar that goes across the ice bucket? As ice fills the bar raises up and eventually goes high enough to shut the maker off until the level goes down.
You can manually lift the bar up to ~ horizontal until it clicks in place and stays there. That should shut it off until you move it back down. If there is no bar, then I guess there in no way your ice maker knows when it is full and keeps producing. Perhaps the bar was removed, bent or broken off. At least tht is one type of ice maker I'm familiar with. Other types my have different ways to tell the maker it's full.
Mar 12, 2018 | KitchenAid Refrigerators
Holiday mode refrigerator
If it is on Holiday Mode, press the key just once more. Page 8.
KitchenAid KSSC42QMS01 Use Care Manual
Jul 24, 2013 | KitchenAid KSSP48QMS Side by Side...
My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
We have a KitchenAid KBRS19KTSS00 bottom freezer frige that keeps getting frost build-up and the food doesn't stay frozen....could it be frost behind the drawer that needs to be thawed out to make the...
If the door has a gap, certainly ice build up will occur on the evaporators and block the air flow which will just accumulate more and more if you don't defrost it first. make sure the doors always shut.
Dec 17, 2017 | KitchenAid 20.3 cu.ft. Counter-Depth...
Refrig door does not seal shut.
jack up the two front leveling feet a bit to make it lean towards the back. or put a level on it to see how far it is off.
Dec 04, 2017 | KitchenAid Superba Architect KSCS25IN Side...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchenaid Refer Icemake not working
The light is supposed to flash twice with a 1 second intermission. When the fridge door is closed the light stays ON. Check this by pushing the white flap to the right of the icemaker while the door is open
Dec 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
