Question about Sanyo DP50749 50 in. Plasma TV
Won't channel up and down, stuck in input mode
Sanyo tv channel button on right side only changes between video, pc, etc like it's in input mode. I can't find the original remote, the remote from another sanyo tv changes the channel by directly hitting the numbers I want, but will not go up and down through the channels with the up and down button. It does the same as the button on the side of the tv as if its in input mode. How do I get it out of input mode? Pressing input is not working.
  • Sanyo Master
  • 1,205 Answers
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Posted on Mar 25, 2014
SOURCE: I have a sanyo mode DP19649 TV. I want to use
I found it and it works! 10463
Posted on Mar 15, 2010
SOURCE: Lost the remote & Sanyo Vizon is stuck on a "D" screen
If you use a tv dish or cable box you could program the cable or dish remote to control your tv. Look up the codes online
Posted on Jan 20, 2009
SOURCE: Can not change channel on my Sanyo LCD TV
I have not solved it but, when I play the dvd player it seems to make everything else work....
Posted on Feb 15, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
JulesPCaut
  • 702 Answers
SOURCE: problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Posted on Dec 03, 2010
My green light comes on but no picture
Sounds like tv is on wrong input. Be sure HDMI wire or cable input is connected to tv. Look at which input it is on. ( like HDMI 1. Or cable etc. take tv remote (with cable box on ) press input / video button and arrow down to different inputs ( slowly ) until the right input is detected or simply go to the right input you noticed the cable was connected to. Different inputs are there for different sources of connections like DVD. Games. Etc. each work like its own tv channel. Good luck.most times this happens when you are watching tv and press the TV. channel button which will take you to a different tv mode
Aug 10, 2014 | Sanyo DP42746 42 in. Plasma Television
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
How do i get to video mode without original remote
you should have an input button. if so press the button until you get to the input that your dvr/vcr player is on. if you do not have a input button got to the menu button and you should be able to change the input thru the menu.
Jan 11, 2010 | Sanyo AVM-2759S 27" TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Sanyo DP50749 50 in. Plasma TV Logo
281 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
