Question about Whirlpool WGD8800YW Cabrio Platinum High Efficiency Gas Dryer Static Reduce Opti
Squeaking Cabrio dryer when running
Squeaks until it heats up good
  • 33 Answers
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Posted on Mar 28, 2014
SOURCE: Maytag dryer squeaks during cycle
I have a Maytag electric dryer model # LDE7334ACE that squeaks while running through the dry cycles. It began as some squeaking at the beginning of the cycle and then it would stop. Has recently progressed to squeaking off and on throughout the cycle. Can you please provide
Posted on Mar 11, 2009
  • 864 Answers
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Posted on May 29, 2009
projdoc
  • 2237 Answers
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Posted on Jul 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Model WED6200SW0 cabrio dryer does not have
84d6194.jpgThis is the area that needs your attention. The heater is on bottom and held by 2 screws, remove it to look for breaks or check it for continuity. If the heater is good then one of those limits(probably the small one on top) has failed due to a blocked vent pipe. The bottom limit is 250f and the op is 300f. If the top is bad the bottom is bad too because it did not shut down. Now go impress someone Tiger. Oh and be sure to unplug the dryer before removing the rear cover. Rate the answer so in case I am wrong, someone else can have a shot. But i am never wrong.
Posted on Mar 03, 2010
ftw1952
  • 10319 Answers
SOURCE: Dryer squeaks while running. What could the
The seal around the drum is dry or tacky and or the belt tensioner roller bearing needs to be replaced
Posted on Mar 28, 2010
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
First it started squeaking when it was running. Now it squeaks and doesnt heat while running Model #GLER331AS1
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Frigidaire GLER341A Electric Dryer
Dryer runs and heats but has squeaking noise. Drum seems to labor mid cycle and then shuts off. If I turn cycle to off and wait unit will resed and begin cycle again with normal heat. Squeaks in on off...
Hello & Welcome to FixYa
The squeaking sound comes when the belt is either broken or worn out and needs replacement or the idler pulley is bad. If you want to do this yourself then you can check this video on YouTube:
Please get back to me if you have any other questions.
Kevin
Jan 30, 2011 | Kenmore 73932 Gas Dryer
The dryer is a whirlpool cabrio is heating. How ever it makes a loud sqeulling noise what do i do?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 02, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
When ever the dryer is running it make a horrible squeaking sound until the load is done. How do i stop it from squeaking?
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 20, 2010 | Dryers
Dryer squeaks when you start. warms up it goes away
It may be one of the tensioner pulley wheels either starting to fall apart or the spindle it runs on in need of a little grease. They often start off squeaking until they've warmed up a little. Then the noise goes away after 5 minutes or so.
Feb 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool WGD8800YW Cabrio Platinum High Efficiency Gas Dryer Static Reduce Opti Logo
189 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
