Question about Hagen Fluval 406 External Filter
Output expels waste
I've cleaned the canister twice and each time, after turning the filter back in, white, flaky waste exploded all over into the tank.
Eheim 2080 will not pump
eheim 2080 filter , only 4 months old, will not circulate water. I took it down to clean filter material and hoses . Put it back together and back into tank but it won't circulate the water. I prime it and prefilter fills with water but as soon as you stop priming there is no output from spray bar. I have read and reread booklet 10 times and believe everything is right .....help
Dec 08, 2013 | Eheim 2520800 2080 Canister Filter...
6.0 hp 12 Gallon Shop-Vac 'exploding'
Those type of vacuums are designed for light duty work around homes anyways. For commercial industrial work as you are doing you need a sump pump. We used to drop one in a 5 gallon (20 liter) pail, drill holes in the pail and suspend from a rope. (you can put screen around the pail covering the holes if needed too). Use a stiff hose to expell the water. You can change to a flat hose like a pool waste water hose or fire hose after the water is out of the trench.
Nov 20, 2013 | Shop Vac Vacuums
Rear canister valve
Hi there Coire, it's Jack at Dyson.
The valve you've described is the suction relief valve. This will open when something is restricting airflow through the vacuum cleaner.
In normal use, we recommend washing both filters at least once a month, as shown in the video above. Use cold water without detergent, and allow at least 24 hours for both filters to dry completely somewhere warm before replacing them in the machine.
If you find this doesn't resolve the issue it's likely your machine has a blockage - to locate and remove this, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
For any further advice after you've given this a try, please contact our experts directly by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 09, 2013 | Dyson DC24 Animal Bagless Upright Vacuum
What's a canister filter?
The canister filters usually located on the floor below the tank. In canister filtering the water is pumped, at moderate pressure through a filter material. Canister filters are especially useful in aquaria with large or numerous messy eaters that generate a lot of waste. You'll have to clean the filters frequently for it to be effective.
Aug 09, 2012 | Fish
If I turn to back wash, will I lose sand. Should I use waste out to clean the filter
Backwash is meant to clean the sand and remove dirt from the filter.
Waste simply pumps the pool water to the drain line and doesn't clean the sand.
If the filter has its distributors, the sand should be held in the canister.
Gary
Jun 27, 2011 | Hayward SAND FILTER, PRO SERIES
My hotpoint aquarius df61 do not clean properly cannot find the problem all filters cleaned .all of the crockery comes out dirty
Just had same problem. Checked and cleaned spray arms filter and impellor. Still had problem. Noticed that it appeared to be expeling water to drain at wrong time. Openned mid cycle and noticed water level low.
Took off left side panel to reveal pipework. Main pipe route big oblong in clear plastic had a red valve at the top which was gunged. This was the air release so when water is pumped in air has nowhere to go so it pushes water out through the waste so ther is too little water in machine. Removed this component and used caustic soda to dissolve food waste blocking valve as there is no access. Put it back together and now it works fine. Took about 2 hours (1 hour for caustic to work) no special tools other than star screwdriver required as it all unclips.
Nov 14, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My canister machine kicks off immediately after starting and bag full light goes on but it has a new bag
hi from uk your problem with vac may be the gauze filter on the inside of the compartment that has bag this filter there to allow air from the micro pores of the bag to expel to the exterior of vac (room) whilst preventing dust from expelling too ? normally another symptom of this is the vac cover sometimes flips up ? however if air cannot expel from compartment it will cause overheat of motor resulting in auto cut off but will reset when cooled SO check the filter gauze and renew or wash clean? hope you understand above and hope this helps ?
Oct 09, 2009 | Electrolux Guardian Bagged Canister Vacuum
Back filter and its door blows off as soon as I turn it on.
thats good has good suction i guess there should be a cover on that back filter if you can't find you can tape it down leave air coming out
Jan 31, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux vacuum turning off
hi take off canister cover remove bag now if you look inside canister you will/should see a gauze type filter at the opposite end of canister from where bag locks in ?? remove this gauze filter and for now just shake tap on floor to remve dust/debri etc /from it this gauze is the filter that when vac is working andfilling the dust bag ? the pressure of air only that blows bag up but allows only air to pass thro the microscopic holes in bag ? then has to expel via the gauze filter to exterior ? and any dust etc that is clever enough to seep through the bag ??? will not pass further due to gauze ? and so prevents this blowing back into room ok so far ?? if this gauze is blocked due to whatever ?? then pressure build up in canister will result in cover lifting? this is provided that the fault is not the actual cover securing latch is ok and not damaged ? hope this explains and helps ? best wishes from uk !
Nov 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Hagen Fluval 406 External Filter Logo
73 people viewed this question
Top Hagen Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Hagen Fish Expert? Answer questions, earn points and help others
