Question about Janome Sewing Machines
Unable to make buttonhole
I have tried and tried to make 1 buttonhole #16 without success.
  • Janome Master
  • 7,365 Answers
Did you put the buttonhole foot on?
did you put the button in the buttonhole foot?
did you pull down the buttonhole lever to the left of the needle?
did you choose the buttonhole program you want?
if you answered yes, to all these questions then it would be a good idea to have the machine checked to see why it won't make a button hole
Posted on May 05, 2014
HI WHAT FUNCTIONS DOES THE JANOME JFS 1817 COME WITH. CAN I DO BUTTON HOLES ETC
Try Googling (janome)(JFS 1817)(manual) without parens to find out.
Jul 13, 2017 | Janome Sewing Machines
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Is it possible to override the automatic buttonhole setting on a Necchi ex30?
Are you asking if you can do a buttonhole without the special buttonhole feature? If so--of course you can. Sewists do it all the time on machines without the buttonhole feature or special feet. Be sure to practice on some scrap fabric first.
Until Wednesday Calls How To Manual Machine Buttonholes
Feb 25, 2016 | Necchi Sewing Machines
Can I sew buttonholes on a 5525?
If your machine has a straight-stitch and zig-zag function, you can always sew buttonholes. It would be helpful if your machine has the ability to set the needle left-center-right, but a buttonhole can still be done even without this function. Whether or not your machine has a programmed buttonhole function will be included in the owner's manual.
Just practice on scrap fabric before trying it on your garment.
Feb 19, 2016 | Sewing Machines
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
When I make a buttonhole, it starts off O.K. on the first side then it makes a straight stitch on the second side.What can I do?
It sounds like your timing is going off, may be time to get a service. A blunt needle can also cause this problem but I expect you have tried that.
Apr 17, 2015 | Sewing Machines
Can't complete a manual buttonhole
Don't think of it as a button hole. Run 2 lines of satin stitch (both forward) about 1/4 an inch apart. Bar tack the ends. Voila'! Large button hole.
Mar 03, 2017 | Husqvarna Sewing Machines
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Designer 1 reverse won't select, no light at all
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Dec 30, 2008 | Husqvarna Viking 1
Buttonhole
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Jul 27, 2007 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
117 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
