Question about Panasonic Jet Force HEPA Bagless Upright Vacuum
Won't turn on
As I was using the vacuum it automatically shut off. I thought I may have accidentally unplugged the cord, but no. It just quit working and it won't even turn on anymore. Its only been used 3 times.
    Top Expert:
  • Panasonic Master
  • 34,217 Answers
The container may be full.
Posted on Mar 25, 2014
Testimonial: "I opened it up and cleaned it and removed all of the clogs. It sat for about 45 minutes and I turned it on again. It worked but did the same thing as last...was on for about 2 minutes and it shut off again."
My vacuum used to shut off after 20min, now vacuum will not turn on
This must be a common problem with the Dirt Devil SD30035 cannister vacuum cleaner. I had this trouble come and go for a while, then it was in solid and would not turn on. Took it to the local authorized service shop. It took them 7 weeks to fix. Said the cord windup real was broken and they had to wait that long to get the part. Two months later the unit would not turn off, so now I have to turn it off and on by unplugging or plugging in the cord. I want to open it up, but can't see how to do it. Sorry I'm not much help, but at least you know this unit has a flaky on/off switch and related circuitry.
Jan 14, 2014 | Dirt Devil SD30035 Canister Vacuum
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Myu easy flow central vacuum wi not shut off
This could be because of 2 things....
first, the on/off switch may have been accidentally hit and is forcing the machine to stay on at all times.
Second, the relay in the unit may be defective and stuck in the on position. Less than 5 years should be under warranty. The easy way to tell if it is this problem tho is to unplug one of the low voltage wires from the side of the unit. These are usually located near the power cord going into the machine. If the machine stays running it is the Relay. However if the machine shuts off, the wiring in the vac system may be crossed out somewhere causing the machine to stay on.
Nov 04, 2010 | Easy Flo EF2300 Central System Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Wind Tunnel vacuum motor won't turn on
The fact that you wiggled the cord and it came on would seem to indicate a defective cord, either at the plug end or at the machine itself. Look again at where the cord enters the vac and at the wall. twist it slightly if you see a thin or collapsed area that is your problem.
Sep 18, 2009 | Vacuums
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums shuts off during use
 My guess is: Either a loose contact on the plug  or Intermittent electricial open  in the electric cord itself. To confirm. Try wiggling the cord and ends while running. If you find the place yo ucan either replace the cord or repair it.
Dec 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The vacuum won't turn on
it could possibly be a short in the power cord. try replacing the power cord. if that doesn't fix it, it would probably be cheaper to buy a new vacuum cleaner.
Oct 12, 2008 | Bissell 6594 PowerForce Bagless Upright...
Panasonic Jet Force HEPA Bagless Upright Vacuum Logo
103 people viewed this question
Top Panasonic Vacuums Experts
Joseph Hoffmann
Kevin Getz
Kevin Getz
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
