Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
How to change the freezer gasket on a Sub-Zero 650?
How do I do this? Do I need to remove the door, or can I leave it on? I would think I need to remove it first.
In my opinion this the easiest sub zero door gasket to install.The main reason for this is because of the way its packaged in the box from the factory.Not being twisted up makes it way easier then any of the others. And yes the first thing to do is remove the food and then pull the drawer out. Then loosen all the the quarter inch screws holding the metal strip that keeps the gasket in place but don't remove them just loosen. Once those are lose remove the old gasket. You should also remove the screws on the end of each metal strip. This helps when re-installing the new gasket. Now put freezer door face down with both rails sticking straight in the air and you can drop the gasket over the rails. The gasket has a small round bead that tucks in behind the metal strip. As you tuck this behind the strip work your way around the door snug in the screws be sure not to tighten them to much.Once in place take a hair dryer and warm any places that look wrinkled or need straightening. Finally tighten all screws including the eight corner screws now re-install freezer door and your finish.
Posted on Jun 24, 2014
  • 183 Answers
SOURCE: sub-zero 650 / bottom freezer
Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
Posted on Aug 23, 2007
SOURCE: leaking sub zero 650
I fixed my leaking problem by pulling out the vegetable drawer and checking the condensation drain hose. Sure enough, it was clogged and the condensation had nowhere to go but move out toward the front of the fridge, down the left side and onto the floor. Once that drain hose was cleared (with a bendable straw), no more leak!
Posted on May 08, 2008
  • 56 Answers
SOURCE: I nee to tighten up the freezer door handle on a
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Posted on Apr 23, 2009
  • 37 Answers
SOURCE: Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Posted on Sep 02, 2009
  • 291 Answers
SOURCE: i have a sub zero model number 550....the freezer
You have a pluggeed drain line. You have to turn off your freezer for a day and leave the door open to dry this out before you work on this problem Unscrew the light bulbs so they don't stay on. To repair this you have to remove the evaporator cover to get at the drain tube. The evaporator cover is held to the freezer ceiling by several screws. Usually two covers come off. Make note of which screws go where, as some models use different size screws. The right side of the evaporator cover is usually silicone sealed and you will need to cut this with a razor knife if it doesn't peal off. Once the cover is off you will see a drain hole on the upper right hand side wall of the freezer. Their are several ways to clear this out, I use a pump up garden sprayer to shoot pressurized hot water through this line from the top and from the bottom of the drain line. To get to the bottom you need to remove the bottom kick panel(two screws) and remove the condensate pan. Note how the pan sits and how it is hooked in the front. You can then see the tube coming from the freezer and you can shoot water through this tube with your sprayer. I sometimes use a smaller plastic tube or a semi fexible wire to run through this line to clear it out. Don't use a hard wire as you don't want to poke a hole through this plastic drain line. Once you have this cleared out you need to clean off all the silicone sealant off of the cover and the side wall. Once everything is clean and dry you must reassemble the evaporator cover and silicone seal it around the drain line. I usually put some sealant on the cover around the drain and some more on the wall before I put the cover on, and then touch it up once it is reassembled. Be careful that you don't get sealant into the drain tube. Let the sealant cure for a day and turn ;your freezer back on. In rare instances the insulation around the drain line in the wall has gotten water in it and has frozen. This destroys the insulation and the drain line will keep freezing up. If your freezer keeps leaking water you will have to buy a drain line heater that Sub-Zero has come out with as an after market repair part. It has very good instructions in how to install this heater into the line to keep it from freezing. Good Luck Appliance Specialists
Posted on Dec 14, 2009
How to open sub-zero 650 condensor cover ?
The cover has 3 bolts, open refer unit door, in the ledge of the box just above the door, you will/should fined 3 screws. Remove them and tip the panel toward you slowly, release the two springs and remove panel. Good Luck
Aug 01, 2014 | Sub-Zero 650 / O Bottom Freezer...
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Freerzer not working ice on roof
You either left the door open for a period of time or have a bad door gasket. Either way you need to remove the ice and make sure the drain pan is clear. Easiest way is to unplug or turn off the freezer and leave the door open, the defrost system was not designed to handle a ice ball.
Good Luck
Apr 13, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650: freezer drawer rollers squeak. Any ideas?
dry them off then spray with silicon.also good for cutain tracks.......plastic/metal.
Apr 09, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sep 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero # 650 door adjustment
There are two covers on each side of the door. They are between the door gasket and plastic housing. Remove these covers to access the bolts. They are 3/8 I believe but cannot remember for sure. Loosen the bolts a little adjust door, tighten and test. Repeat till you get a good seal.
Mar 16, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero door seal
THE TRUE IS .. replace a door seal is a little pain to replace. YOU HAVE TO INSTALL RIGHT. ( some model using silicon. if you are patient. and able to remove aroun 30 screws. do it. if not. better call a tech........good luck.............................. LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Dec 06, 2007 | Sub-Zero 642
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
90 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
