Question about Sony KDF-E42A10 42 in. LCD Television
I have sound and picture in picture but no picture / screen
I have no picture, there is a display of unknown objects in blue hue of colors. The sound is perfect and the picture in picture are crisp and clear.
  • 4 Answers
SOURCE: sony bravia lcd tv
Are you connected to a cable box or satalite rcvr using compoment outputs (y,pr,pb)? It is posible that the red cable has come loose and picture has no red,causing a mostly blue picture.
Posted on Jul 16, 2007
mistersony
  • 320 Answers
SOURCE: Color Hue tends toward green
Sounds like a bad optical block
Posted on Oct 18, 2008
ripleymojica
  • 643 Answers
SOURCE: picture disappears after a while
panel is bad not econimical to repair.
Posted on Jun 02, 2009
Sparko1
  • 167 Answers
SOURCE: Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Posted on Aug 08, 2009
Testimonial: "Optical block was the problem and has been replaced and TV is like new. Thank you for your response."
SD Tech
  • 14553 Answers
SOURCE: Picture is not as clear, brought 2005. Has blue color on lower right side of screen.
You may want to do some research with the model number via Google--"problems"
The set indicated here is LCD rear projection--it uses a OPTICAL LIGHT ENGINE and a lamp= lamp shines into the engine and goes thru a series of lens and baffles and emerges from a 2-3 inch wide lens at top of engine--shines it into a mirror at the rear of set which places the picture on the screen.
The first place the very bright and hot lamp hits inside the engine is the BLUE SECTION----damage occurs and you get blue streaks or area anywhere on picture.
Damage is permanent and only way is to replace 800 + engine.
You might want to at least call Sony with the model number as they were extending the warranty (beyond original) on several models and repairing or replacing sets outright.
They were not doing this because they wanted to but because of several class action lawsuits they settled in this way.
Posted on Apr 11, 2012
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Screen has a blue hue...how do I correct his?
choose the menu button on your monitor move over to the picture option and it should display your color option in that menu a long with the hue as well
Sep 10, 2014 | Acer B243W 24 inch LCD Monitor
Red blue hue on picture
ur color setting has certain problem. from ur remote control go to color setting and set ur req.color
Mar 10, 2012 | Televison & Video
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
Sony Projector Color Display
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
Aug 08, 2009 | Sony KDF-42WE655 Television
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Sony KDF-E42A10 42 in. LCD Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
