Question about Hamilton Beach 04922 TrueAir Replacement Carbon Filters for 04160 And
Carpet is tinted black and black film on everything
I use the replacement in my daughters room and her cream carpet now is tinted black when i move things and a black film on everything.
    Top Expert:
  • Hamilton Beach Master
  • 34,206 Answers
You do not say what the device is that uses the carbon filters but if air passes through it the carbon may be blowing into the room. It also is possible that dirty air is passing through the filter without being cleaned.
Posted on Mar 25, 2014
Steam wets the hardwood floor or the carpet
The steam is condensing as it is expelled. The solution is to place a sheet of plastic underneath the unit to protect the surface
Jan 03, 2013 | Holmes Products HM500-UC 1 Gallon...
Hi, We just purchased a vicks warm mist humidifier. We used it for two nights in my daughter's bedroom...we then noticed a sticky residue over sections of the wall as well as crackling paint? Is this...
is it possible that you have the mist turned up too high? If the room is very small, the high setting could be providing too much humidity to the room. I'm thinking that the paint crackled as the humidity climbed.
Nov 04, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Emitting a powder residue
its minerals in your water. not harmful at all.
Aug 07, 2017 | Vicks V4500 1 Gallon Humidifier
How do i know if my humidifier is working? it doesnt produce the white mist
Check your humidistat and it should click close to what you have it set on. Also if your humidifier is not working you can rub your sock feet on the carpet and touch a door knob and get a little shock.
Jan 05, 2010 | Holmes Products Humidifiers
Humidifier creates film on everything in the room it is in.
the white film is just dust particles from the unit. it's also a bit of condensation that is building up. the particles are not harmful. but it's nice to keep it clean after every use. also the film is coming from the vicks. that is normal. so nothing worry about as far as harming the childs air or anything.
Apr 27, 2009 | Vicks V4500 1 Gallon Humidifier
Won't humidify past 30% in a 90sf bedroom
The most probable reason that the humidifier does not reach the levels you describe is because you said you had the unit in your bedroom.
Bedrooms typically contain materials that are known as "hygroscopic." What that means in plain English is that items such as the bedding, mattress, any carpeting, wood, curtains, you, etc. all absorb moisture , kinda like a sponge. Since that moisture is being held by these materials, the air itself contains less by percentage. 25-30% humidity is actually pretty good for any room, especially in colder climates and higher humidity levels can lead to the production of mold, condensation on windows, etc., which are not good things. The good news is that reasonable humidity levels are healthier for textiles such as carpeting, cloth, and so on because the fibers won't dry out and crack. Dust is also reduced, but again, only to a certain level.
If your humidifier is reaching 30% it's probably working ok.
Mar 27, 2009 | Hunter 33201 Humidifier
Clarion da1030 steamed carpet to white?
Hi, I really hate to give bad news it affects my ratings! The hot water didn't bleach the carpet, more like washed the color out. The dye in the carpet was no match for boiling hot water and the result was washed out spots. You can try to find some commercial dyes to fix the spots or replace the affected area. Sorry!
Feb 06, 2009 | Clarion DA-1030 Humidifier
Water Tank leaks all over the floor
This happened to me the second night of use.  Water all over the carpet and a dripping vent. I called customer service and they told me to remove the tank and filter, and run unit dry for an hour or so. Then restart it.  Worked fine after that.  I think we may have bumped it which is said to be the cause of most leaks.  Bummer is that after 5 night of use the grip on water tank slipped and the tank is in pieces.
Nov 12, 2008 | Honeywell HCM-300T Humidifier
Kenmore 14-gallon humidifier--only right bottle will drain
I just read the reviews because I am considering buying it, and many owners complained of the same problem. Many people said they tried to fix the problems by leveling the machine, however, one guy said he figured it out: just level the machine slightly toward the REAR and it drains correctly. Try it. I hope he's right, because I'm going to take a chance on this machine and it better work well!!! :)
Mar 27, 2008 | Humidifiers
Water on floor around humidifier
I haven't had any problems with my Vicks Cool Mist Humidifier other than the fact that the area surrounding it is slightly wet after operating for a couple of hours....While I understand that I was using this to moisturize the air during a cold, I knew this would happen, because the air in my room is not dry. If the room isn't dry, the mist that it's putting out in to the air has no where to go but surround the humidifier. All I did to stop this was to buy a water proof mat. I suggest you do the same -- Also, in regards to the water smelling -- You should be cleaning out and drying the basin after every use. Water shouldn't smell unless you let it stagnate inside the plastic -- Try running distilled vinegar through the machine for a couple of minutes -- Also, I would use an extension cord and let it run outside so that your house doesnt smell like Vinegar.
Oct 18, 2007 | Vicks Cool Mist V400 Humidifier
Hamilton Beach 04922 TrueAir Replacement Carbon Filters for 04160 And Logo
49 people viewed this question
Top Hamilton Beach Humidifiers Experts
Mack Baxter
Dennis
Are you a Hamilton Beach Humidifier Expert? Answer questions, earn points and help others
